Username: Kaprese Walstonburg,
NC
Post Number: 140 Registered: Mar-07
Sunday, May 13, 2007 - 14:26 GMT If a was to place my amp under the front seat and run my amp again, would the shorter run of power wire make a difference in output or anything at all ?
Username: Killswitchjd Post Number: 552 Registered: Apr-06
Sunday, May 13, 2007 - 14:38 GMT i think the difference would not be noticable, but some difference would occur
NC
Post Number: 141 Registered: Mar-07
Sunday, May 13, 2007 - 14:46 GMT Then why does everyone say "the shorter the wire the better"
Username: Killswitchjd Post Number: 555 Registered: Apr-06
Sunday, May 13, 2007 - 15:02 GMT It is better, but you wont notice a change. However there will be less loss of power to heat
Username: Splmonster C-Town,
OH
Post Number: 1052 Registered: May-06
Sunday, May 13, 2007 - 15:16 GMT yep nate is right the shorter the better, but u couldnt noticably hear a difference.
Username: Nd4spd18 Southeast PA
Post Number: 2354 Registered: Jul-06
Sunday, May 13, 2007 - 17:08 GMT All it will do is reduce voltage drop *slightly* at the amp. Not enough to make any audible difference, but enough to gain you maybe 0.1-0.2 db in competition.
