Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12731 Registered: Oct-05 | you are a whore. rofl. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2529 Registered: Jul-06 | Hey,what I do with women and my body is none of your concern. |
Silver Member Username: Waterboy2289Georgia, DiRtY SoUtH ... 2 18 SX w/ ... Post Number: 412 Registered: Jan-06 | ^^^A pompous whore. |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12734 Registered: Oct-05 | hahahaha. not that i got your attention, link me to the voltage meter you have. a web link that is. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2531 Registered: Jul-06 | http://www.cardomain.com/item/STISVMB I got her for 19.99 plus shipping back on promo. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2532 Registered: Jul-06 | Here she is in action http://www.putfile.com/pic.php?img=5186000 Not bad voltage either eh? |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12735 Registered: Oct-05 | i need that. so i just connect the red to the + and the black to the - on the trunk battery and i am good to go? |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12737 Registered: Oct-05 | which one should i get? |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2533 Registered: Jul-06 | Haha.It doesn't show the remote wire.Go from amp input positive,whatever ground and a remote.Get yourself whatever one you like most but I'd personally get one of the rectangular style ones. |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12740 Registered: Oct-05 | i should get 2 then. so i can connect one to each amp. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2534 Registered: Jul-06 | They mount up nicely and you can put it in a smaller area than the round gauge.I'd also put a switch on it the voltmeter because you might get annoyed of it for some reason or another but I don't. |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12742 Registered: Oct-05 | k cool. so this is what i do then.........get 2 meters. one for each amp. connect the red wire to the power cable on the amp and the black wire to the ground cable on the amp. then the remote to the remote. do the same for the other amp too. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2535 Registered: Jul-06 | Yea, you can do that but I have my remote wires hooked to a switch so I can shut off whatever whenever.Oh and another thing I tested the voltmeter side by side with a DMM and it was very close so it's a reliable reading.The reason you run to the amp is so that you know exactly what the amp is seeing,if you run from somewhere else you might not see the voltage your amp(s) are/is seeing.Driving didn't listen to this and well...let's just say he's lucky to still have his equipment in working order. |
Silver Member Username: Joebruce15 Inch Wang... Post Number: 870 Registered: May-04 | Chad i like the first one. I think you should get a couple round ones and put them in your pillars that would look sweet,just a thought. |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12748 Registered: Oct-05 | won't that be too riced out? if i do get the voltage meters, i am not gonna install it in the front. ima put it on the little space i have below my box. i have to turn around to see the voltage but its cool. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2537 Registered: Jul-06 | I reccomend putting them somewhere they're easily visible when you're controlling your HU.If you have to mount em back there then do it. |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12749 Registered: Oct-05 | yeah it will be visible easily. i just need to turn my head to see it. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2539 Registered: Jul-06 | Alright,cool.Order those bad boys up It'd be cool if they made them in green.I really like the Tsunami one that Eric has on here but it's like 70 bucks and quite over-sized for my install. |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 4333 Registered: Jan-06 | i want one of those PG volt meters they are sexy looking. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2541 Registered: Jul-06 | "i want one of those PG volt meters they are sexy looking." Why say something and not post the link!?!I'll google it...I'm lazy. |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 4336 Registered: Jan-06 | i dont have a link to post, iv only seen one on someones install. they have them on ebay but you have to buy the amp to get it which i might actually do, after i do a little more hunting. |
