Username: Mgbcs Lincoln,
Nebraska
Post Number: 1276 Registered: Dec-06
Wednesday, May 09, 2007 - 00:39 GMT Hey guys. I am setting the gain for my temp amp and I am wondering what you think this amp really puts out. It claims 850RMS at 2ohms, but I am assuming it's overrated. I need to know the watts so I can plug it into the equation thing. Thanks. I appreciate it. Ben
Username: Snarl2004 Audioque 12 SD2.5s,
Earthquake P...
Post Number: 1232 Registered: Dec-06
Wednesday, May 09, 2007 - 00:49 GMT probly somewhere in the 800range but i got no idea. Try setting it by ear
Nebraska
Post Number: 1283 Registered: Dec-06
Wednesday, May 09, 2007 - 02:02 GMT Yeah that's what I try to do, but I end up blowing fuses before my ear says stop. Either way, I wanna do it right. Anyone else have an idea?
Username: Nd4spd18 Southeast PA
Post Number: 2218 Registered: Jul-06
Wednesday, May 09, 2007 - 02:09 GMT I actually used that exact same amp as a temp amp, lol. Kenwood amps are CEA rated so it should do that power on 14 volts, their quality just sucks.
Nebraska
Post Number: 1288 Registered: Dec-06
Wednesday, May 09, 2007 - 03:58 GMT Oh...well that's good to know lol. Thanks MS!
Username: Tc_skier Post Number: 194 Registered: Oct-06
Friday, May 11, 2007 - 18:26 GMT do kenwoods break down real easily?
Username: Andrew571 Stillwater/Edmond,
Oklahoma
Post Number: 813 Registered: Oct-05
Friday, May 11, 2007 - 19:10 GMT ^ yes. They are famous for internal power supply problems
Post Number: 2317 Registered: Jul-06
Friday, May 11, 2007 - 21:03 GMT ^^^^ X2 what he said
