CW600sp, Remote is inop @ times.
Username: Daneegha
Post Number: 67
Hello everyone!
My CW600sp has been good since day one; except few days ago the remote stop working @ times. It works with tv and other components except for receiver. I tried new batts and still do the same I'm thinking possibly bin affecting, but I don't want to mess with it until somebody give me an advise...
Thanks!
Username: Leines
Post Number: 26
never had a problem with mine.. but i use an aftermarket learning remote..... my normal remote is workin fine...
Username: Daneegha
Post Number: 68
Ok, Now it's getting worse; First the problem was with the remote, now it won't work from the buttons on front panel, only buttons "menu ok and channel down" working. I reload bin to see it that helps but no luck. I'm sarting to suspect I have a bad receiver...
If anybody have a clue, please advise..
Thanks!!!
