What is the best FTA receiver to purchase?
Username: Malew
Username: Senators
Post Number: 117
for support with bin i would say viewsat
Username: Senators
Post Number: 118
for bin support i would say viewsat
Username: Farooq1371
sonicview, the support team for viewsat and sonicview is the same.
Username: Tapeman
New York City in-HD, NY
Post Number: 1129
I will have to say:
Viewsat PVR 7000 (Price range about $300 USD)
Simple reasons:
- 2 tuners (watch and record) or record 2 events
- Program/record future movies/events etc.
- You want to record as many as movies before PTA turns cold
- You can install up to 2TB HDD
- With a simple modifications you can share in 2 different rooms
This is how to
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1063352#POST1063352
= No HD capability no DVD burner for PVR 7000
*** make sure you know where to get BIN PGM before you buy
I honestly got no clue where to get these BINs?
Second choice will be:
Captiveworks CW 3000 (Price range about $500 USD)
Because it has limited HD capability + DVD burner
Same applies where to get their bins
Third choice for Low Cost receivers will be Viewsat Magnum or extreme ($160 to $180)
No recording capability, no HD reception
I do not recommend to anyone to buy any HD receivers however my first 2 choices still best value available today
Username: Lklives
Post Number: 9388
There is no such thing as "Viewsat Magnum", chief...
There is a Extremeview Magnum for less than $145 ...and that is a very good receiver
BTW...the Viewsat Ultra has them all beat with the USB stick...
and any Viewsat, Sonicview or Extremeview, sure is hell is much better than any captiveworks..
Username: Tapeman
Post Number: 1131
Correction
Thank you LK
I meant Extremeview Magnum
The PVR 7000 has Front Panel USB 2.0 supported for fast PC interface. What I see more impressive that it has 2 tuners PIP and record feature etc.
Most people got recording devices instead of buying 2 devices this has both Tuner plus recorder.
At last is what you can afford and where to get from is totally up to the user.
Username: Brucester
Post Number: 493
i think captive works is the best box for the money you pay great support good epg all for 110CAN the cw600p keep up the good work cw and team
Username: Ftanl
Post Number: 48
I'll have to agree with you Bruce I. The Captive Works CW600P is the best bang for your buck. It's easy to setup & so far so good with little or no problems. I've set up a few of these & everyone is working like a charm.
Viewsat Ultra is perhaps the best for ease of downloads with the USB feature. But if you own a PC I'd suggest the CW600P to everybody. It's way cheaper.
Username: Runnerguy
Pluto
Post Number: 229
Southcoast fta has Extremeview Magnums for $129 which includes shipping.
