New member Username: Mspatriot15NE Post Number: 2 Registered: May-07 | i just bought 2 SWR-1222D Alpine 12" Type-R.. i dont know n e thing bout this suff...i know eah of the subs are dual voice coil and 2 ohms.... 1500 peak power and 500 RMS each..i need to know how much watts..channels..etc. my amp needs to have to get the full 500 RMS outta each of the subs....im not lookin to spend over $200 for it maybe a little more..thanks everyone} |
Gold Member Username: LbecknerTulsa, Ok Usa Post Number: 1507 Registered: Oct-04 | http://cgi.ebay.com/AUDIOBAHN-A16000V-MONO-1600-WATT-AMPLIFIER-NEW-07-AMP_W0QQit emZ140112987545QQihZ004QQcategoryZ64570QQrdZ1QQcmdZViewItem http://cgi.ebay.com/MA-AUDIO-HK1998-MONOBLOCK-AMPLIFIER-1200W-MONO-AMP-NEW_W0QQi temZ300109082671QQihZ020QQcategoryZ64570QQrdZ1QQcmdZViewItem hard to find something for $200 |
Silver Member Username: ClouduzPost Number: 200 Registered: Jun-06 | I would suggest a hifonics 1606d i believe they are under $200 i think |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1317 Registered: Nov-04 | Here's your cheapest amp choice with a good quality amp: http://cgi.ebay.com/NEW-06-JBL-GTO1201-1-II-2-MONO-AMP-1200-WATT-PLEXI-TOP_W0QQi temZ290114291448QQihZ019QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem You'll need to have sub's coils wired in series and subs in parallel - if you're getting it professionally installed, be sure to tell the installer that...they may mess it up. The amp you get needs to be 2ohm stable. That JBL is probably your best bet. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2215 Registered: Jul-06 | Definitely do not get an audiobahn or MA audio. Hifonics are ok, and that JBL would be good. |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1320 Registered: Nov-04 | Ok we're not starting another "audiobahn" thread, but they're absolutely NOT a terrible brand and I'd never say "definitely do not get." I've had my amp for 4 years and it's awesome. Isaac has personally tested their intake series amp and said it's a great deal for the money...the amp puts out the power and is decent quality. Anyway, go with that JBL b/c the audiobahn one's not the right match for the setup. |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1324 Registered: Nov-04 | Ok we're not starting another "audiobahn" thread, but they're absolutely NOT a terrible brand and I'd never say "definitely do not get." I've had my amp for 4 years and it's awesome. Isaac has personally tested their intake series amp and said it's a great deal for the money...the amp puts out the power and is decent quality. Anyway, go with that JBL b/c the audiobahn one's not the right match for the setup. |
Gold Member Username: JohnfiacA-ToWn, 152-153db Da... My wangers b... Post Number: 2684 Registered: Mar-06 | JBL Bp1200.1 used |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1327 Registered: Nov-04 | No real need to get that used one when the newer models are pretty fairly priced as is. |
Gold Member Username: JohnfiacA-ToWn, 152-153db Da... My wangers b... Post Number: 2685 Registered: Mar-06 | I only suggest it because it is also 1 ohm stable, non like the new ones that arent(future upgrades are easier) it does like 1300-1400rms at 1 and 2 ohm... |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1330 Registered: Nov-04 | I don't know about that amp being 1ohm stable... http://manuals.harman.com/JBL/CAR/Owner%27s%20Manual/bp_om.pdf There are new JBL models that are 2ohm stable and there're others that are 1ohm stable (i.e.: bpx1100.1 and bpx2200.1). |
Gold Member Username: JohnfiacA-ToWn, 152-153db Da... My wangers b... Post Number: 2686 Registered: Mar-06 | the bp1200.1? It is |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1333 Registered: Nov-04 | Where does it say this? |
Gold Member Username: JohnfiacA-ToWn, 152-153db Da... My wangers b... Post Number: 2687 Registered: Mar-06 | look in the pdf you linked above.... it says lowest stable load 1 ohm* (* = gets the same power as 2ohm) look at the specs for the list of amps... looks like all the BP (mono blocks)series are 1ohm stable, 2 ohm optimized |
Gold Member Username: OlegSanta Monica, CA USA Post Number: 1334 Registered: Nov-04 | I see...very interesting. |
Gold Member Username: JohnfiacA-ToWn, 152-153db Da... My wangers b... Post Number: 2693 Registered: Mar-06 | bad@ss amp... for a used amp i dont think you can really beat it for 200$ if not cheaper... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4575 Registered: Dec-05 | ^^^^x2 |
