18" q in ext. cab
Username: Garciag
Post Number: 167
so do you guys think this would fit in my extgended cab i have like 2 feet from the back of the cab to the rear of my seats, think thats the only place where i would have to worry about room
Username: Garciag
Post Number: 168
an another question whats the bp power option for on the Q
Username: Garciag
Post Number: 169
bump
Username: Livin_loud
F uck fuckid... Fi Audio
Post Number: 1785
it would fit but you'd pretty much have to make a wall. 18's require a lot of space. don't know about the option. i got mine before there was any. e-mail fi
Username: Garciag
Post Number: 171
hows that 18 sound compared to anything youve heard before does it get loud enough for you
Post Number: 1790
it gets much louder on >40hz than most 2 sub setups around here i've seen, but they haven't been anything special. but mine is also in a trunk. overall, i'm happy with its performance. it gets pretty loud, and it is an sq sub after all. if you properly install one in your situation, you'll love it
Username: Garciag
Post Number: 172
sounds good thats what im looking for to get louder that 2 subs with just one and there aint many good systems out here either best one ive heard is 2 p3s or 2 15" cvrs was the loudest
Username: Surferdude9371
Maitland, Florida
Post Number: 69
i have an ext cab ranger i right now have a solox 18 in there and am in the process of getting a 18 btl it fits and sounds fine my box is angled so i still have room.
Username: Hgihkcin
Lincoln, NE
Post Number: 175
i just did an install on a 18" q, it gets lower than crap, and it sounds amazing, it never distorts, i wish i would have had more than 5.5 cubic feet to work with though....
Username: Garciag
Post Number: 173
you guys have any pictures or anything to show so that i can look at the box design and i also looked at the bl not much price difference so i might go with that to, i just need help on the box so any suggestions
