Alternator suggestions?
Username: Thomas_g
NM
Post Number: 2298
Im looking for an HO alt to power an xx colossus, it will be in an 93 ford explorer, can someone name a few that will have enough power for my amp?? Thanx.
Do you think a 220amp, 160 amp at idle would be enough?
Username: Joebruce
15 Inch Wang...
Post Number: 848
Iraggi alts are pretty cheap on ebay and they seem to have a good rep. Im planning on gettin one when i get some money.
Username: Thomas_g
NM
Post Number: 2299
thats where i was looking i only found the one i listed above to be the biggest, i think i would need a bigger one for my amp.
Username: Nd4spd18
Southeast PA
Post Number: 2288
220 is pently big enough unless you plan to drive down the street playing test tones at full volume
Username: Thomas_g
NM
Post Number: 2300
kewl M.S. so it should be good right? Im going to a local comp and car show next month and hope to take it!!
