Bronze Member Username: Xx_elixir_xxPost Number: 25 Registered: Feb-07 | I have a pair of JL 12w3v2 D4's, is the KENWOOD KAC-7203 2 CHANNEL 1000W AMPLIFIER a good amp for them? |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 671 Registered: Mar-06 | No. Prob look at a 800 rms amp. What is your budget? Kevin |
Bronze Member Username: Xx_elixir_xxPost Number: 26 Registered: Feb-07 | well... I wanna stay under $200, if it is more then I'll have to save up. |
Bronze Member Username: Xx_elixir_xxPost Number: 27 Registered: Feb-07 | hey, how about Visonik... I have never herd about it but I saw this - http://cgi.ebay.com/ebaymotors/VISONIK-V217SX-800w-RMS-2-1-CHANNEL-CAR-AMPLIFIER -AMP_W0QQcmdZViewItemQQcategoryZ38638QQihZ017QQitemZ270118655221QQrdZ1QQsspagena meZWDVW |
Silver Member Username: ClouduzPost Number: 199 Registered: Jun-06 | kenwood has a HIGH failure rate, stay away!!! Visonik, is low budget, i had a 400w one that put out rated power though |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2214 Registered: Jul-06 | Kenwood and Visonik are both complete crap. Take a look at this before asking about anything else: https://www.ecoustics.com/electronics/products/articles/329117.html |
Bronze Member Username: Xx_elixir_xxPost Number: 28 Registered: Feb-07 | thanks |
Bronze Member Username: Xx_elixir_xxPost Number: 29 Registered: Feb-07 | I still don't know what to get though. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 2459 Registered: Jul-06 | I'd look into Kicker,Elemental Designs and Hifonics as a last pick for a "Good" budget amp. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4574 Registered: Dec-05 | Hifonics bxi 1206d, lanzar vibe 1200d/1800d (i own it and it works nice at 800w), optidrive 1000.1 made by zed audio, orion 600D, diamond audio 800.1, memphis prd 1000 |
Bronze Member Username: Xx_elixir_xxPost Number: 30 Registered: Feb-07 | o.k. how about this? http://cgi.ebay.com/AUDIOBAHN-A8002V-2-Ch-Intake-Amplifier-800W-NEW-07-HOT_W0QQi temZ140114725689QQihZ004QQcategoryZ39732QQtcZphotoQQcmdZViewItem |
Gold Member Username: CtmikeCt. Post Number: 4294 Registered: Feb-06 | i personally wouldn't get it. i second the zed amp, it'll push those subs nicely. great amp at an unbelievable price. just a little more than your budget but you wont regret it. http://www.soundsolutionsaudio.com/shop/index.php?act=viewProd&productId=41 |
Bronze Member Username: Xx_elixir_xxPost Number: 32 Registered: Feb-07 | that list is all monoblock amps. I have 2 Subs, don't i need one with 2 channels? |
Gold Member Username: CtmikeCt. Post Number: 4296 Registered: Feb-06 | no. |
Bronze Member Username: Xx_elixir_xxPost Number: 33 Registered: Feb-07 | ? |
Gold Member Username: CtmikeCt. Post Number: 4297 Registered: Feb-06 | you can run more than one sub off a mono amp. for your subs: http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?suboptions= Mono%5F2%2D4ohm%2DDVC&type=mono |
Bronze Member Username: Xx_elixir_xxPost Number: 34 Registered: Feb-07 | o ok. |
Bronze Member Username: Xx_elixir_xxPost Number: 35 Registered: Feb-07 | Is Lanzar vibe 226 any good? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4578 Registered: Dec-05 | No. Get something stated above. You won't regret it |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 741 Registered: Oct-04 | Just to answer the next 5 questions.... If its brand new....and cheap..... No. Get what you pay for. |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1297 Registered: Mar-04 | That Visonik looks like a decent deal for the money to me. Not all that powerful though - in the 400w neighborhood. That list is ridiculous - it can be picked to pieces just like all the other ones people have written up. I like how infinity amps are "questionable" while JBL are good. A lot of those amps are EXACTLY the same inside. Helix in the same category as Hifonics?? Those lists are pointless. Almost every brand in the bad list has some stuff that would do just fine for the typical hobbyist. It's just stupid. The vibe 226 is spineless -- 160w rms. If money's that tight and you really want some power - Julio's Lanzar 1800D suggestion is a good one imo. The 2600D Lanzar Heritage is a good budget sub amp too. You can get refurbs on ebay for around $150. Your pair of DVC 4's can be wired for 1 ohm - and would work well with a mono amp that's 800-1000w at 1 ohm. |
Gold Member Username: JohnfiacA-ToWn, 152-153db Da... My wangers b... Post Number: 2713 Registered: Mar-06 | "I'd look into Kicker,Elemental Designs and Hifonics as a last pick for a "Good" budget amp." haha rob since when has kicker been a budget amp? there stuff is pricy |
