APX
Username: Mikeneufeld
Abbotsford, BC Canada
Post Number: 40
need some input on these subs for final decision... will the atomic 500.1 run 2 15's good and how do they sound and compare up against dd 9515's and mojo 15's as for sql if that even goes in the same sentence.. any feedback would be great..
Username: Nd4spd18
Southeast PA
Post Number: 2303
I think those are SPL subs..... so I would take the 9515 for SQL.
Username: The_image_dynamic
San Diego
Post Number: 1282
That amp puts out 500 RMS @ 1 ohm. How do you figure that is going to push two 15's and especially two APX's?
San Diego
Post Number: 1283
Maybe he meant to say the Atomic 5000.1?
Post Number: 41
whats makes the 9515 superior to the apx 15....
Post Number: 42
lol 5000.1....lol.... sorry
San Diego
Post Number: 1285
Well he said it would be superior to the APX for SQL. The APX is built for brutal power (15k+ burps) and wasn't really designed to sound all that great. The 9515 will hit very hard while still sounding pretty damn good.
Post Number: 43
thats what i like to hear so i guess 5k to 2 apx 15's would be harshly underpowering them...
San Diego
Post Number: 1287
Nobody said that. The APX's are very efficient and would be fine on 2500 RMS each, but they are not SQL drivers and I thought that was the original question?
Post Number: 44
yes. that is correct.... i can get 2 for such a good deal thats why i ask... thank you very much for the input...
Post Number: 45
thanks boizzzzzzzzzzzzz
Username: Bump05
CashMoney, 15 Hd3 USA
Post Number: 1102
na man 2500rms on a apx would be fine, not harshly underpowering then i wouldnt do no more then 4k tops rms on each 2500 will get em moving but the 9515s will be better for daily just letting you know, apx's are great for the mic
Post Number: 46
i can't seem to find the weight of an apx 15, on the specs at atomic, does anyone roughly know this?
thanks,,,, mike
