Subwoofers
Username: Spiffy
Well, I'm currently in the process of setting up a system, and I'm at the stage of buying subwoofers/amplifiers.
Car: 1988 Ford Escort GL
Modifications: Replaced factory radio with Pioneer DEH-P6900UB.
Want: A subwoofer system that'll give me good thumps when listening to bass heavy music (such as rap).
What I'm looking at: Pioneer TS-W301R, Pioneer TS-W307R.
And the amp?: That's why I'm here.
Budget: I'd like to stay below $300. (I can get subs for roughly $100).
I know there are alot better subwoofers out there, but when browsing through subs, I found that the Pioneers gave alot better hits as compared to an Alpine Type R. Granted, the Alpine looks like it'll last longer with the rubber seal and plastic cone.
Username: Ctmike
Ct.
Post Number: 4276
so is $300 for subs and amp? and personally i'd take the type r over any pioneer sub, pretty sure most here would say the same. and what subs can you get for $100?
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 7221
Type R FTW!!!
Username: Dakangofkrunk16
Post Number: 86
x2^
Username: Spiffy
I can get either of the Pioneers (both of them) for around $100.
I know that the Type Rs are great, my buddy has 3 10" Type R's in his truck, and they sound great.
My only thing is that I can get the Pioneers for cheap, and they gave a greater hit when I compared them. I used the same amplifier, same song, same everything, I just swapped the subs. The Pioneers hit harder, and gave more of a thump. My only problem is that the Type R's will last longer (rubber seal and cone), whereas the Pioneers have a foam & rubber (I think) seal. But I'm one who will take care of my sound system, and I'm just trying to figure out which Pioneer was better.
Which is better: Pioneer TS-W301R or TS-W307R?
Yes, the subwoofers and amplifier are all included in the $300. So I'm looking at [b]about[/b] $200 for an amp. Overall I need to know what the best amp is to run 2 subs, and which Pioneer subwoofer is better?
I do want to stay open to input regarding subwoofers, but I think that $100 for two 12" subs isn't too bad.
Username: Renegadesrun
Lafayette, IN US
Post Number: 718
Im trying to imagine anyone having the same set-up long enough to have the surround deteriorate from age..........
ahh screw it, I cant do it!
Direct sub swaps do not tell all. Just what will work best in the given enclosure with the given power.
Was me? Id pick the Type aRRRRghhh. Tried, tested, proven loud.
Before some idgit brings up Pioneers record. I will remind them that it was pioneers money that hit that number, not necessarily the sub.
Username: Sound_r_us
Post Number: 15
Depending on what voice coil config you get on your subs depends on the amp you need. Try to match the rms of the subs to the rms of the amp.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
type in your info and that will tell you your options for wiring it... try to find a amp as close to this as possible.
200 dollars for an amp isn't much so ebay is probably going to be your best bet. Use the fowwing list for brands. (under amps)
https://www.ecoustics.com/electronics/products/articles/329117.html
Username: Ctmike
Ct.
Post Number: 4287
"My only problem is that the Type R's will last longer (rubber seal and cone),"
that is pretty darn funny^^^. and are you saying the cone is rubber to?
but again, don't get the pioneer. imo they suck. spend your money better. and i'm with renegade, just cause you swapped subs in the same box means jack shi_t. put them both in the correct box for each, give each the proper power, and you'll take the r.
