Suggestions
Username: Sound_r_us
Post Number: 13
I recently was employed by best buy, so I've started to plan out a system. I will use my employee discount on an amp, but plan on buying the subs somewhere else and building my own box...
I used to have a 15" Treo SSi... so I'm trying to get something close to this for not as much.
SQL... for sure
I was thinking an Audioque Street Duty 2.5 Series powered by an http://www.bestbuy.com/site/olspage.jsp?skuId=8265548&type=product&productCatego ryId=cat03087&id=1170289779572
Rockford Punch 1000W Class BD Mono Amplifier wired at 2 ohms to put out 500 watts.
I think the amp will be a lot cheaper as most car audio has serious markup.
If anyone has any better suggestions about a sub to run preferably a 15" thats cheap and good... I'm all ears. Or if best buy sells a better amp, let me know as well.
Thanks in advance
Username: 04redmach1
Columbus, GA USA
Post Number: 670
You can run that amp and a RD Audio Alpha 15 D2 :-)
Kevin
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2305
thata mp prolly pulls 700-800 watts @ 2 ohms. I would look into a different sub. Maybe an RE SE or Massive Audio CW. Not saying the Audioque couldn't handle it. Just think the other would outperform it.
Post Number: 14
how much does an RE SE 15" run ???
