Pansat 2700 no sound?
Username: Danman08
i have no sound and i did a factory setting and it is still the same. any answers would be great thanks.}
Username: Mrskullz1
Brooklyn, New York
Post Number: 402
1. Check the mute button on tv and on the receiver.
2. Check your cable connections. If you are using RCA jacks then it should be the white/red cable that you have to check.
3. Make sure all connections are secure
4. Check the settings on your STB
5. Does it work with like a dvd or something? or is it just the receiver? if its just the receiver than its most likely a connection problem.
