Getting started
Username: Adddisorder
West palm, Florida
Post Number: 4260
hey guys, what do i need to get set up to well get free channels. can you please provide links and maybe a little description, i tried looking threw this forum but its full of spam. also i would like to keep things pretty cheap if possible
Username: Lklives
Post Number: 9389
Buy a Viewsat Ultra (about $165) receiver from www.totalfta.com and start READING for about 20 hours..then u will have a good newbie grasp and should be able to install and align the dish on the roof, run the cables, setup 1-2 receivers in the house, and watch TV..
Username: Mrskullz1
Brooklyn, New York
Post Number: 385
lol welcome to the sat section mat
u on a budget? if u need info on this sign on aim
basically do as listed above and you will be fine...i kno ur not a dummy so mos of this will/should make sense to you right away.
if anythin i'll b on aim sometime tonite
p.s. how was nero? workin good?
West palm, Florida
Post Number: 4276
yeah im thinking about setting up a sat. and stuff just wondering what all is involved.
just reading threw the info LK posted and stuff.
and thanks for nero its been working good.
Username: Lklives
Post Number: 9429
heres a Viewsat Ultra AND a Dish 500 (110-119 sats) for $170...good price..
http://www.ftabins.net/showthread.php?t=4661
Username: Lklives
Post Number: 9430
Actually $170 or BO...VERY NEGOTIABLE..maybe even grab it for $150, which is a steal..
Username: Grub
Post Number: 101
do you also sell used cars?
Username: Jerkisland
Post Number: 11
Hello LK,
Thanks to PRMNJ and you that most of my issues with PANSAT 3500 are solved.
I have a question about the image you had uploaded earlier.
Currently I have same LNBs as shown in the picture but I have one cable running from Dual LNB (61.5)and another from Twin LNB (119)and they are connected to a switch. Now I was planning to connect in the same fashion as shown in the picture so that I can get channels from 110 which I don't get right now. There are two outputs on the Twin in the picture, one is going to 3500 and other is going to legacy 4700. 3500 should be connected to the output shown in picture or it doesn't matter, it can connected to the output where legacy 4700 is connected to ?
Please let me know. Please note I am not trying to connect two recievers. I have only one reciever (3500SD)
Thanks in advance
Username: Lklives
Post Number: 9452
If U use the Dish Pro PLUS (DPP) Twin LNB in pic above U will NEED a 2nd receiver (DN) to power that DPP Twin LNB..and use the same outputs as shown above..U must do as the pic shows above, except sub your 61.5 for the 148 and use NO switches...
Post Number: 12
LK,
Thanks for the response. LK, I don't need a 2nd receiver and I don't have one. I want to get channels from 110 , right now I only get 119 and 61.5. Currently I have the above LNBs but not connected as shown in the above picture, instead I have one output coming from Twin and one output from Dual and they are connected to a Switch.Also I tried connecting another cable to the 110 output on the LNB and connected to the switch but I still didn't get any 110 channels.
What should I do to get 110 channels, connect in above fashion shown in the picture ? if yes will it power the LNBs ?
Please advice.
Username: Lklives
Post Number: 9459
I believe u probably have a Dish Pro Twin LNB now, NOT a Dish Pro PLUS...read the logo on that LNB again..if U have the DPP LNB U will need a 2nd receiver or power inverter to power the DPP LNB..
Post Number: 13
LK,
You are right, I have a Dish Pro Twin (119)and Dish Pro Plus Dual (61.5). Thanks for making me understand what I have. Now how do I connect these to get 110 channels, please let me know.
Thanks for your patience.
Username: Mike_m
Post Number: 35
need some advice just recieved a quantum 3000 what bin would i load and from where.he used to get all the paperviews and all and how do i get into the menu it seem the normal pasword my friend was using 0000 is not working. i cant get into nothing not even factory reset.my pansat 3500 is working well trying to toy with this and help my self learn with out damaging my box any help will help thanks
