New member Username: Angelo921Post Number: 9 Registered: Apr-07 | I just got my new Pansat 2700a today. I have a 31 inch dish satellite which is pointing to 101W Satellite (which was used for Dish Network in the past) and is giving me 85% signal. I verified this before hooking up the 2700 by hooking up an old receiver and going into the signal settings. I then hooked up the 2700 directly to my TV (without using the included switch) and then went into the 2700's settings for "antenna setup" and it shows a bunch of satellites. My question is which satellite can I choose in order to get what ever FTA programming is available in my area without hacking the box? thanks Angelo |
Gold Member Username: NydasPost Number: 2592 Registered: Jun-06 | I suggest you look at the following URL. 101W might not be the right direction http://www.lyngsat*com/america.html |
New member Username: Angelo921Post Number: 10 Registered: Apr-07 | I got the 101W by hooking up an old Direct TV receiver which I had service from my old house, could the 101W have come from the settings on that receiver? The reason I ask is because Dish Network was previously installed at this home and not Direct TV. |
Silver Member Username: Albino_midgetPost Number: 508 Registered: Jul-06 | 101W = amc4ku in sat list free to air channels/sats |
Gold Member Username: LklivesPost Number: 9327 Registered: Jan-06 | If the previous owners had DN installed , then there is NO way U get 101W..yeah the DTV receiver may "indicate" that to you, but it's NOT happenning! |
Bronze Member Username: Angelo921Post Number: 11 Registered: Apr-07 | Im aware that I wont be getting DTV, I actually want to be able to get whatever FTA is out there according to where my satellite is pointing. |
Silver Member Username: HardrockstrikerPost Number: 807 Registered: Apr-06 | FTA uses linear lnbs. Your dish has circular. If you want to use true FTA then you will need linear lnbs and you may have to re-aim your dish. |
Bronze Member Username: Angelo921Post Number: 12 Registered: Apr-07 | A friend of mine helped me update the 2700 with bin 203 and we hooked it up to the tv and with Echo 7 and Echo 8 Im getting level ranges in the 80% range but the quality level never moves from 0% regardless what the settings are at? What can cause the level to always remain at 0%? thanks Angelo |
Silver Member Username: HardrockstrikerPost Number: 812 Registered: Apr-06 | Dish isn't aimed properly. Also, incorrect lnb type or switch port setup in receiver. |
Bronze Member Username: Angelo921Post Number: 13 Registered: Apr-07 | where can I change the lnb type or switch port setup on the Pansat 2700? I dont see that anywhere in the settings. thanks Angelo |
Bronze Member Username: Angelo921Post Number: 14 Registered: Apr-07 | sorry my bad, i spoke to soon, the lnb type Ive tried is standard and Dish-pro and neither of those work in regards to changing the quality from 0%. WOuld the only other thing be that the satellite on the roof isnt aimed correctly? thanks Angelo |
Bronze Member Username: Angelo921Post Number: 15 Registered: Apr-07 | Would the dish not being aimed properly still give me a level 83% while also giving me 0% Quality? thanks Angelo |
Gold Member Username: LklivesPost Number: 9337 Registered: Jan-06 | yes siree Billy Bob.. |
Bronze Member Username: Angelo921Post Number: 16 Registered: Apr-07 | Is it relatively easy for me as a home owner to adjust the dish to be able to get the Quality? Perhaps with help from another person? (one to be on the roof and move the dish around the other to watch if the Quality changes? |
Bronze Member Username: Angelo921Post Number: 17 Registered: Apr-07 | Is there a way that I can tell in the settings on the Pansat 2700 what degree the dish is exactly pointing to currently? thanks Angelo |
Gold Member Username: LklivesPost Number: 9338 Registered: Jan-06 | what is this Jeopardy!...go READ at the hundreds of DSS sites about dish alignment! |
Gold Member Username: LklivesPost Number: 9339 Registered: Jan-06 | what is this Jeopardy!...go READ at the hundreds of DSS sites about dish alignment!...and they have calculators to use to help u align/aimthe dish towards a specific satellite from your specific zipcode and location...provides the dish elevation, azimuth, and skew adjustments needed...in fact, read the RECOMMENDED REPUTABLE sites thread here, they are listed in that thread! |
Gold Member Username: LklivesPost Number: 9340 Registered: Jan-06 | Future FTA - Blacklist's Site: [link removed] (C00LSAT and All receivers) DSS Newbies: [link removed] (Pantecs,all clones and all receivers) File Share Site - No Registration Required: -------------------------------------------------- Good for gettting Original factory firmware: [link removed] Best site for DISHNET info, channels, transponders and changes etc.. [link removed] [link removed] |
Bronze Member Username: Angelo921Post Number: 18 Registered: Apr-07 | OMG I dont know where to start. LOL |
Gold Member Username: NydasPost Number: 2593 Registered: Jun-06 | Enas Filos : YOU ARE NOT AIMED AT A SATELLITE THAT WILL GIVE YOU WHAT YOU ARE LOOKING FOR. You will have to SWING the dish and align it properly. If you are not sure about it get somebody to do it for $50 - that is the usual price for going on to the roof and aligning it properly. To read about it, join a site from one of the URLs, such as There is a wealth of information out there at those sites and many more sites, and it is very well catalogued and classified for easy reading. |
New member Username: CruiserChatham, ON Canada Post Number: 2 Registered: May-07 | I have a pansat 2700a with dual lnb's that go through a sw21 switch. I do not kmow the proper skew or elevation to set my dish at. It was changed by a friend and he screwed it up. I get nothing now except for no signal can anyone help me with elevation and skew. I live in Chatham, Ontario, Canada. Any help would be great. Thanks |
New member Username: SmallsPost Number: 1 Registered: May-07 | hi ppl i'm super new at this stuff.i bought pan 2700 clone how and what sites do i go to get my reciever going anyone' please |
Gold Member Username: NydasPost Number: 2597 Registered: Jun-06 | rbhcanada : http://www.remotesat.com/lookangle.htm |
Gold Member Username: NydasPost Number: 2598 Registered: Jun-06 | alvin monkman: To read about pan 2700 clone, join a site from one of the URLs, such as Make sure you look for full details and instructions. The 203v Tivo is the BIN. |
New member Username: SkyhighNorth miami beach, Fl Us Post Number: 1 Registered: May-07 | I baught a pansat 2800A and I got a directtv multi satelite dish with one LNB not the original LNB it came with conected to my pansat receiver, I connected the null modem cable between the pc and the receiver then I open the GTRom loader then I selected the bin file to download then I click download then on my pansat reciever screen, the channels was scrolling up after it was complete the receiver booted it self, when I scan satelites I have chosen it say 0 programs found can I get some help please cause I did download the software |
Gold Member Username: NydasPost Number: 2607 Registered: Jun-06 | lrigby : Look at my post just above yours. You have quite a lot of reading to do. |
