I need help i re-set factory settings
Username: Vicb
pls help i dont know why but i re-set my factory setting to do a new blind scan on echo 7 @ 8 . i i have nothing tired to scan and nothing pls help
Username: Vicb
i did a blind scan and it says cant find transponders
Username: Vicb
i got it. i had to re set the diseq to get a signal then do a blind scan :-)
Username: Eatfish111
Post Number: 251
woooohoooo way to go bud always good when you figure it out on your own.
Username: Vicb
Post Number: 7
hey getting waiting for picture now that i blind scanned.. do i need to do the b-80 reboot
Post Number: 252
no just wait for keys to roll
Username: Vicb
Post Number: 9
ok it rolled but my local channels r back to the old way before the new 319 bin should i re do the boot 80 file
Username: Vicb
Post Number: 11
and now im getting double channels and missing channels.. shouls i reboot the 80 and my lastest bin
Username: Vicb
Post Number: 18
got it all tha ks thear closed
