Silver Member Username: Joebruce15 Inch Wang... Post Number: 760 Registered: May-04 | Anyone no where i can get one of these for cheaper? http://cgi.ebay.com/Stinger-4-Gauge-Power-Wire-Coupling-Coupler-SPT5211-HPM_W0QQ itemZ170106184888QQihZ007QQcategoryZ50549QQrdZ1QQcmdZViewItem |
Silver Member Username: BudlingCali USofA Post Number: 334 Registered: May-06 | Pretty sure thats about as cheap as you can find it. |
Silver Member Username: Joebruce15 Inch Wang... Post Number: 761 Registered: May-04 | Well do you think a place like Radio Shack or Home Depot would have somethin like that? |
Silver Member Username: Mrskullz1Brooklyn, New York Post Number: 355 Registered: Feb-07 | bestbuy should....?? |
Silver Member Username: BudlingCali USofA Post Number: 335 Registered: May-06 | They will have the ones you crimp. Just solder it. |
