Another Kicker question
Username: Kanishka
Post Number: 25
I am not working today and did some tests on my subs.
i did the tests with a kicker soloX 18" and a Kicker solobaric L7 15"
when i put the max volume soloX rocks and no question about it, cos it's 5000 W
my question is when i put both subs at 1000W - 2000W both sound the same. no difference at all.
is there any thing wrong with my setup or is this normal ?
max for L7 is 2000 W and max for 2000 W for solox is less than half.
Username: Solobaric4life
Post Number: 764
if u only had 2000watts max power runnin each seperately thats why, but i still think the solo-x 18, would be louder because cone area but that is no where near enough power to make the x loud as it can be, u need around 2500rms just to wake the x 18 up lol
Username: Th3pwn3r
Post Number:...
Post Number: 2419
Kanishka,forget about MAX power,the MAX power for the Solo X is 10,000 Watts.The RMS is 5,000 watts.Anyhow...the Solo X should be louder than the L7.How do you have everything wired?
