Power Cap not on
Username: Mash4kash
Lafayette, LA
Post Number: 284
I was just setting my gain and the power cap was on when I turned the car and music on the power cap was off, still off wtf going on wit it? Its a Power Acoustic 3.0 farad cap
Username: Van_man
Boston South, MA
Post Number: 2358
They dont stay on all the time. The light that is, Leave the car off and put the lights on, it will come on counting down the volts. When current is stable, it shuts off.
Username: Mash4kash
Lafayette, LA
Post Number: 285
I tried that, never came on. Even the digital voltage indicator didn't come on.
Username: Mash4kash
Lafayette, LA
Post Number: 286
bump
Username: Nd4spd18
Southeast PA
Post Number: 2140
Just take it out, lol. It's a capacitor, not like it's helping your electrical system any......
Username: Van_man
Boston South, MA
Post Number: 2366
check the ground on it. got it wired right?
Username: Mash4kash
Lafayette, LA
Post Number: 288
yep got it wired just like that
Username: Johnfiac
A-ToWn, 152-153db Da... My wangers b...
Post Number: 2675
Power Acoustic <-thats your problem
Username: Mash4kash
Lafayette, LA
Post Number: 289
hows massive audio power caps?
Username: Jeromebaker
Post Number: 122
A cap is a cap is a cap. Aside from the size they are all the same except for the sticker on the back.
If you buy another cap you are paying for the sticker. That is all.
Power acoustik is just as good a cap as any other.
You will not have better performance with a massive audio cap.
But, if you don't want to listen and want to just keep going with different caps, I have 2 that I'll let go for cheap. One is a tsum=nami 5 farad and one is a PA 1.2 farad. $150 for both, say 170 shipped. But I don't advise the use of a cap without a HO alternator.
Username: Nd4spd18
Southeast PA
Post Number: 2408
I don't advise the use of one at all..... unless you want to blow some money for something the looks cool. Then go for it
