Bronze Member Username: Justin_15_07Manitou Beach, Michigan United States Post Number: 58 Registered: Apr-07 | I have 2 audiobahn 10s ran the same way but for some reason only one gets warm, the magnet and coils stay fine, but in the front where it says audiobahn gets noticeably much warmer than the other, what should i do? |
Silver Member Username: JblanfordPost Number: 884 Registered: Oct-06 | well obviously the coil is getting warm if the dustcap is warm... is there any difference in sound/performance ? |
Silver Member Username: Freezeman_7Lindsay, Oklahoma U.S.A Post Number: 962 Registered: May-06 | get different subs but really, energy creates heat. so if you have two amps, maybe one is set higher than the other, or one is wired wrong |
Bronze Member Username: Justin_15_07Manitou Beach, Michigan United States Post Number: 59 Registered: Apr-07 | No loss or anything, just a little bit warmer, they are wired the same, the amps are set exactly the same, checked with a DMM, a loose speaker wire maybe? its not getting HOTT but definatly heat, and these things arent cheap so im curious what u guys think |
Silver Member Username: JblanfordPost Number: 886 Registered: Oct-06 | "and these things arent cheap" |
Gold Member Username: MgbcsLincoln, Nebraska Post Number: 1142 Registered: Dec-06 | Well, they are pretty cheap. |
Silver Member Username: SplmonsterC-Town, OH USA Post Number: 910 Registered: May-06 | lol i got a kick outta that too joe |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2091 Registered: Jul-06 | Yep, Audioburn FTL |
Gold Member Username: MgbcsLincoln, Nebraska Post Number: 1143 Registered: Dec-06 | If everything is set correctly, then just keep pounding away. There isn't anything you can do. Start saving up for some new subs, because you will likely need them. |
Silver Member Username: Freezeman_7Lindsay, Oklahoma U.S.A Post Number: 966 Registered: May-06 | true taht...^^^ anyone need some firestarters?? lol |
Gold Member Username: The_image_dynamicSan Diego Post Number: 1046 Registered: Dec-06 | This reminds me of the time I walked into a local pawnshop just as some guy was buying an Audiobahn Flame 10". I told him -- hey man make sure you check that thing, those things are notorious for burning coils. So he says nah man I already checked it. So I walk over and push down on the cone and it is completely seized, no movement at all. I said see I told you man, it is blown. He gets all serious and says no way man that's the way they are, the suspension is bad azz on these things. So I laugh and walk back over and push down super hard so he could hear the coil scraping and say -- still think it's not blown?. He grabs his wallet and walks out of the store with his head down and just then the owner tells me to never come back again so I said cool I don't want to shop at a place where the owner is too stupid to actually check used subs when they come in |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 6123 Registered: Jun-06 | Same pawnshop sell fake rolex's?? |
Silver Member Username: SplmonsterC-Town, OH USA Post Number: 911 Registered: May-06 | hahaha well u shoulda juss let the idiot buy the blown sub, but i guess ur a nicer guy than me lol |
Silver Member Username: JblanfordPost Number: 888 Registered: Oct-06 | wow brad...you are one hard motherf@cker j/k |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 618 Registered: Mar-06 | I am wanting to know how much he paid for the a-bahns since they weren't cheap Kevin |
Bronze Member Username: Justin_15_07Manitou Beach, Michigan United States Post Number: 61 Registered: Apr-07 | man these are f,ckin the ultrahigh excursion series, f-ckin over 250 each |
Gold Member Username: CtmikeCt. Post Number: 4189 Registered: Feb-06 | not a bad price for a sub, but way to much for a shi_tty sub like audioburn. |
Silver Member Username: Freezeman_7Lindsay, Oklahoma U.S.A Post Number: 974 Registered: May-06 | i got my ssds for 189 shipped each and they were sealed and would have kill those burns |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2118 Registered: Jul-06 | " man these are f,ckin the ultrahigh excursion series, f-ckin over 250 each " Lol that's a ripoff |
