Solo x's
Username: Gula187
Baton Rouge, Louisiana USA
Post Number: 60
for the people that destroyed their solo x's how huch power did you have running to them and how much power should you run to a s18x
Username: Surferdude9371
Maitland, Florida
Post Number: 53
ive got the 18 it blows all the time you can run the kx2500.1 to the 1 ohm version or if you wanna get it loud do 2 kx2500.1s
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1098
You should be fine with just about any amount of power with that thing. I think Kickers are just so poorly made that any inconsistancy or mistake will kill 'em.
Username: Dakangofkrunk16
PLANET EARTH, FLA
Post Number: 904
they needa stop worrying about what other shape subs there gonna come out with Triangle, Oval, Pentagon, Octagon or w.e
and try to make the solo X better or make sumtin else i like there round subs it is more like Kicker Squares Sux
Username: Gula187
Post Number: 61
anybody heard both subs i want to know which sub can get louder
Username: Jkidder
Spring hill, Florida Usa
Post Number: 488
we r only talkin about one sub tony!
Username: Gula187
Post Number: 63
damn my bad have anybody heard the solo and btl 18 or have heard both
PLANET EARTH, FLA
Post Number: 923
i heard both i say BTL 18 all the way Kicker if ur G@y lol JMO
BTL SPL wit good Sound Quality serieous Power tho id reccommend atleast 2500 ime give mines 4000 each
Solo just SPL shty sound Quality Possibly gonna break quickly blah blah spairs no one cares FI BTL ftw fully costumizable n much cheaper
Username: Gula187
Post Number: 64
thanks anyone else ...........but i heard that the new spairs are going to be louder and stronger so...
Username: Th3pwn3r
Post Number:...
Post Number: 2285
"ive got the 18 it blows all the time you can run the kx2500.1 to the 1 ohm version or if you wanna get it loud do 2 kx2500.1s"
Lol...how many things can I say about this?
PLANET EARTH, FLA
Post Number: 926
ok lets say that but rite now
Solo X 18- 1200
Amp-???
S.P.A.I.R-around 200
Not gettin an FI BTL and Blowin ur subs numerous times - PRICELESS
with 2 spairs u can buy a FI BTL 18
Username: Jkidder
Post Number: 495
probably a short story or a moderate novel? i don't even know, where would you start?
PLANET EARTH, FLA
Post Number: 927
"ive got the 18 it blows all the time"
How Much Does IT Charge
i wish i had a sub that blowed lol
Username: Jkidder
Post Number: 497
haha and as long as its 18 u dont have to worry. lol
PLANET EARTH, FLA
Post Number: 928
ha ha i didnt get that at first but then my not wnating to go to jail senses kicked in fluck ima have to see some idea to make sure cause them subs be lying about there age
"how was i suppose to no she was 13 she got hair down there " flcuk fast food wit them horamones givin girls big Fun pillows, buts n hittin puberty faster lol
Dont think im a Pedafile it is a joke but i am a TheRapist
Username: Gula187
Post Number: 65
what subs can get louder than the btl or is that the best tht you can get
Username: 420alldaylong
Post Number: 1593
Tony Harrell
What kind of car do you have?
How many amps is your alternator?
How many batteries do you have?
Username: Gula187
Post Number: 66
well i want two 18's and i have $800 a piece for subs,i thought the solo x will get the job done because i can get a 18 for $600 so......
Maitland, Florida
Post Number: 59
ive never bought a spair everytime my wire melts i just resolder it its about an every three month job lol.
PLANET EARTH, FLA
Post Number: 932
You can get 2 DD 9515 for 800 but if u got room and money get 4 9515's and u'll be booooming 4 sho
Username: Jkidder
Post Number: 500
"Tony Harrell
How many batteries do you have?"
answer the questions, we really need to know.
ALSO, DO YOU ALREADY HAVE AN AMP?
Username: Travis08
i love my SoloX 18
i have 2 type RF X7's
and a 25 farad RF cap
and a 300 amp alternator
and 0 guage wiring all over
i had the T215D4 before i got my 18
i haven't blown it yet and ive had it for about 6 months now and i hit about 151 once i get my new box i should be hitting a lot harder
Username: Th3pwn3r
Post Number:...
Post Number: 2287
Ecoustics gets worse and worse every day :-(
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 611
2 solo x 10s hold the iasca stock 2 record atm or atleast last time i checked...
Post Number: 1606
Tony Harrell
Username: Kanishka
Post Number: 13
hey people on this forum have said that kicker has vibrations and loude sound only and the sq is not good.
is it true. cos i have not used subs other than kicker.
Username: Th3pwn3r
Post Number:...
Post Number: 2293
What kind of charging system do you have Patrick?I don't have any problems with my Solo X blowing from normal use.I blew one VC though after running a 5hz tone,it was just thermally overloaded like crazy and got smoky from it but still worked then eventually gave up.I beat on my Solo X every day though and I don't have any problems with it blowing.The sound quality of them is all opinion,I actually like the sound of my Solo X over my DD 3512,hits the lows much better in my opinion.
Maitland, Florida
Post Number: 67
200 amp alt one red and one yellow top bat 5 farad cap 0 gauge wire
Username: Bernymac
Cambodian
Post Number: 2582
"Ecoustics gets worse and worse every day"
AMEN to that Rob.
This thread won the "Most Noobish Thread of the Day" award.
Username: Johnfiac
A-ToWn, 152-153db Da... My wangers b...
Post Number: 2595
"You can get 2 DD 9515 for 800"
Thats not new is it? Enlighten me...
Username: Th3pwn3r
Post Number:...
Post Number: 2361
"200 amp alt one red and one yellow top bat 5 farad cap 0 gauge wire"
That's not a good enough charging system to run 5K RMS(Rated Power,although you're getting more) off of.If you had a better charging system Patrick you would have never blown that sub and amp up.
Username: Johnfiac
Post Number: 2604
200A is about good enough for 2000Rms, it can do a bit more. If you are running more then the reccomended power dont play it to long so the batterys drain to much, let the batterys charge again ect.... once you see the voltage dropping below 12.5V easy.. you know your down to much power. I would get a volt meter in the car if you plan on running 5K on that.. also it could take out your alternator to, not just your amp, and subs.... if you drop low enough you can fu<k up stuff in your cars electrical\computer system to.
