What would...
Username: Skies
Courtenay, British Colu... Canada
Post Number: 640
When you wire a sub to 1 ohm on a 2 ohm stable amp, what would you look for as a first sign that it's not gonna be pretty? Protection, heat on amp, heat on coil?
Username: Mmaudioconcepts
Murray, KY
Post Number: 131
heat on the amp...
Username: Freezeman_7
Lindsay, Oklahoma U.S.A
Post Number: 979
maybe some nice pretty smoke
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 354
wayyyyyyyyyy back in the day when i was an idiot i had 2 rockford dual 2 ohm subs and an audiobahn a8002t, and i not knowing anything had the subs wired to 1 ohms (thought it was 2 ohm), and the amp pounded for like 8 minutes on end and then would overly heat, this lasted for about 2 months before i learned about ohms and stuff, but yeah you will notice big time heat and once it shuts off, you know your doing something wrong, btw, the amp actually lasted them 2 months and then i sold it because i realized i was an idiot and got the wrong type of amp
Post Number: 982
nice dude, gotta learn the hardway sometimes... lol
Username: Oleg
Santa Monica, CA USA
Post Number: 1224
It actually depends on the amp. Most of them go straight into protection. Some other amps can actually perform at a lower impedance and can deliver more current at that. Depending on your sub's thermal rating and how much power the amp's generating at 1ohm, the coils can overheat. If the amp does run at 1ohm, it'll probably get very hot very fast b/c it wasn't designed specifically for that application. If it's a cheap amp with terrible protection circuitry, it'll fry quickly.
Username: Nd4spd18
Southeast PA
Post Number: 2110
The quality of the amp doesn't much matter. If it wasn't designed for 1 ohm, you will most likely let the magic smoke out.
Bottom line: Don't do it
Username: Skies
Post Number: 650
To let you all know, I did it.
I used my Infinity 7451a bridged, and wired my SSX at 1 ohm, worked great just hit protection a little faster(quite sure its stable at 4 ohm bridged...). I wasn't too light on it, tried a few different songs and turned it up quite quickly, didn't warm up too quickly either.
Anyways, yeah. That's my story :-)
Username: Oleg
Post Number: 1243
I did the exact same thing. The amp I has was PA OV2-1600 or something like that - 4ohm stable when bridged. Wired 2 4ohm DVC subs to 1ohm without knowing anything about amp's ability to perform at 1ohm. Ran it like that for 2 years, clipping subs to death and blowing 1. Then sold it to my friend who's using it to date to power 2 RFs.
Username: Skies
Post Number: 656
Wow, 2 years at 1 ohm?
That's impressive :P
I honestly wouldn't expect that out of a PA amp. Still going too... They're built for abuse I guess.
Username: Oleg
Post Number: 1244
If you hold the amp, it feels solid and pretty heavy. Every time I touch it, it would be burning hot, I couldn't hold my hand on it - I guess I know why now lol I also had 2 of these:
http://www.justamps.com/Amp_Pages/PowerAcoustik/discontinued/pa_faren.htm
1PA-Q2420 got stolen with my sub and 1PA-Q4640 I recently replaced with a JBL. The amp's still functional! I'll sell it for $40 shipped...it's 4x75W
