More suitable?
Username: Theivan
Dawson Creek, British Colu... Canada
Post Number: 95
im currently running 2 10 inch PG Xenons on a JL 500/1. i want to upgrade to an amp that will push them to their max. how many watts should i think about running to them or is the 500/1 pretty much working them to their max? should i go to a 1000/1. what do you guys think? any amps that are better i should go for moneys no problem right now. (yes i might get new subs too).
Username: J_c_wheeler8
Columbus, IN United States
Post Number: 369
If i were you, I would get new subs. and a nice amp to push them. I am currently running 2 alpine type R's, and my kx1200.1 should be coming in the mail soon. The Type R's are in a ported box and im sure u've seen pics. Is space a factor for you? If not, give me a price range for subs, as well as like 1x 15", 2x 12" 2x 15" or still 10's.
Username: Oleg
Santa Monica, CA USA
Post Number: 1148
Ivan, you need about 900W rms for those, that JL puts out 700W rms tops. You need another 100W per woofer, but I'm not sure that'll be audible.
Username: Imalik
SD2.5, New Jersey Audioque...N...
Post Number: 252
The subs are not bad at all...You could look for a Crossfire VR 1000 or EDnine.1... that will give you the power you are looking for. I just ordered a Nine.1 for 2 12 SD2.5.
Username: 420alldaylong
Post Number: 1562
JL amps put out what they say no more or less.
Username: Oleg
Post Number: 1150
No, they say it puts out more...about 200W more.
Post Number: 1563
Who says?
Username: Oleg
Post Number: 1152
Glasswolf. Need I say more?
Post Number: 1565
JL. Need I say more?
Username: Oleg
Post Number: 1155
Yeah, that says nothing.
Username: Theivan
Post Number: 98
JL joey? cause if your dissing JL youve got some issues man.
Post Number: 1609
Ivan
I guess you could say Im dissing JL because you don't get enough for the price. And Im pretty sure there is alot people that agree.
Username: Theivan
Post Number: 100
i kinda agree with you there but i get lots of my stuff alot cheaper just because im cool with the dealer here. theres definetly same quality product for cheaper but i think JLs wear down time is a bit better. ive just stuck with them cause thats whats worked for me
Username: Skies
Courtenay, British Colu... Canada
Post Number: 629
JL has excellent best build quality.
They are quite overpriced though.
JL Amps ARE underrated, roughly by 40%. I have googled, and found proof of it, you should be able to do the same if you're curious.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1141
It's a regulated power supply for a reason...no?
Username: Safe_cracker
Chicago, IL US
Post Number: 2724
JL amps are not underrated by 40%, that is hillarious! If your lucky the 500 will give you maybe 600 rms if your lucky more like 580, that isn't 40%, lol. JL has a nice build quality but for "bang for buck" factor they aren't all that great. Also if you decided you wanted to raise your battery voltage it would do you absolutely no good due to the regulated power. they put out there benched power from 11-14.4V which is great for a vehicle where someone doesn't want to upgrade there electrical but I wouldn't buy one..
Username: Oleg
Post Number: 1202
Glasswolf himself said most birthsheets on JL 500/1 say around 667W rms or in that neighborhood - I'd believe that over other speculations.
Post Number: 1610
Ivan
How much do you pay for the JL 250/1 JL 500/1 and the JL 1000/1
Username: Sinful_systems70
15 INCH WANG...
Post Number: 827
"People who hate on JL are the ones who can't afford it!" JMO
Chicago, IL US
Post Number: 2726
No hating, just much better deals out there, and yes I can afford them, lol.. BTW my 4 kicker sx1250's cost more! :-O Polo..
15 INCH WANG...
Post Number: 829
I wasn't naming names or pointing anyone out, that is just one of my quotes... I agree that there are better deals but there is not better quality than JL.. JMO
Post Number: 1611
Why spend more when you DON'T need to.
Username: Skies
Post Number: 630
Polo.
As I said, GOOGLE IT.
With all due respect.
http://www.carsound.com/review_archive/amps/jl_5001.html
https://www.ecoustics.com/electronics/forum/car-audio/6599.html
500 * 1.4 = 700.
Username: Theivan
Post Number: 101
keep in mind this is canadian $ joey:
the 500/1 i got for 450 and they actually just got the 1000/1 after i bought the 500/1 but i wanna switch if it will be worth it. i can probably get it for around 600 or 700
Post Number: 1613
What would that be in US$
Username: Skies
Post Number: 631
Buying gear from the states goes up exponentially. Customs, brokerage, shipping, currency conversion kill us :-(
a $315USD amp comes to about $560CAD after its all paid for.
a $350USD sub comes to about $620CAD after its all paid for.
It hurts :-(
Post Number: 1616
Well I have to say Glasswolf is wrong on this one because JL slash amps do not come with birth certificate. And trust me when I say they do rated power and no more this is coming from JL AUDIO. They know how many watts comes out of there amps and its 250 for 250/1 500 for 500/1 and the 1000 for 1000/1. I repeat this is for JL AUDIO. If you don't believe me give JL a email.
Username: Oleg
Post Number: 1208
Did you not read the article SkieS posted above?? They tested it! Anyway, I'm done arguing about the obvious with you.
Post Number: 1621
I beleive JL over a review.
Username: Oleg
Post Number: 1209
Then you'll need to believe every other company, too. What they "say" is what they put as their RMS rating. Those zappies then put out exactly what they're rated at and not a watt over. And those pyles are a real bargain @ 4000W for $100. A bit naive, but whatever.
Post Number: 1624
WERE TALKING ABOUT JL AUDIO.
Username: Skies
Post Number: 635
Joey, then you are saying that JL is lying about the output of their products?
Do I have to email them, too, to find out the real answer?
I remember the outcome on the NINe.1 efficiency thread. Do you?
Username: Oleg
Post Number: 1210
SkieS, can I be on your team??? lol
BTW dude, your grammar and punctuation are awesome!
Username: Killswitchjd
Post Number: 494
jl makes great products.
as for output, unless I saw the number on the instrument used by glasswolf to test it the result is impossible to prove. However, I trust glasswolf 100 % if HE would come on this thread and say what it benched.
Post Number: 1625
SkieS
How I'm I saying JL is lying.
Username: Skies
Post Number: 643
"And trust me when I say they do rated power and no more this is coming from JL AUDIO. They know how many watts comes out of there amps and its 250 for 250/1 500 for 500/1 and the 1000 for 1000/1. I repeat this is for JL AUDIO. If you don't believe me give JL a email."
They've been repeatedly tested to put out MORE than rated power.
Post Number: 1626
My bad on my typing.
How am I saying JL is lying.
Post Number: 1627
? If they put out more power why don't JL say so.
Username: Skies
Post Number: 644
If you're saying that you heard from JL themselves, that JL amp slash series does absolute rated power, no more, no less, then you're saying that JL is lying.
Again, JL Slash series amplifiers have been repeatedly teset to put out MORE than rated power.
Post Number: 1628
Email them yourself.
15 INCH WANG...
Post Number: 840
^^"? If they put out more power why don't JL say so."
For COMPS!!!
Username: Oleg
Post Number: 1219
And I thought this was well known, but apparently not. Underrated stuff is for competitors to get away with using alleged less powerful equipment while getting more power from them that rated.
15 INCH WANG...
Post Number: 841
Might as well ask why any company would underrate their stuff!
Username: Oleg
Post Number: 1220
^^^than* rated
Post Number: 1631
Believe what you want to and how often do you see JL in comps you don't there not built for that sh!t.
Username: Shade
Moxee, Wa U.S.
Post Number: 233
i think this comes down to the same concept Cable Internet companies use. Usually you'll order 3mb download speed but in when u goto download you're gettin 3.5mbs. i'm sure they over compensate for heat etc etc..jmo
