im trying to angle my dish to get bev initially i had my dish500 satelitte picking up dn 110 and 119 i moved the dish 18 degrees to the east hooked up tomy pansat 3500 level fluctuates between 25-90 but cant get no signal what am i doing wrong i have the switch setting correct as i have it set to 4 and the reciever is also set to 4 what am i doing wrong?
Terry first thing i would do is Turn off Power to Unit then Disconnect all other lnbs from Switch and then try finding Bev.You might need to adjust your Dish Scew .Make sure that there are no obstructions in the line of site, if there are that is more likely the problem. I have a Bigass Tree in my line of site so it fluctuates. Oh and By the way you really didn't make it clear that you have 2 Dishes, cause you cant get Bev and Dishnet on same Dish .Once you have Bev all lined up, then scan, after that once you properly powered off your unit, reconnect other Lnb's
