manu do you have place you can plug in the back of the box a red white yellow spot to plug the 3 wires in the box and the other end in to the tv you will get better pitchuer with the pluges then with the tv cable
Looking at the back of your tv, if you have an s video input on it and your receiver use an s video and the red and white rca cables for sound (best picture), second best is red white and yellow rca cables, third would be connecting cable to antenna input. Hope this helps
manu . dont replace the cable . u can use that cable even broke. hahahahaha what the fuuuuuuuuck is wrong with you poeple??????????? this site is getting too lowwwwwwwwwwwwwwwwwwwwwwwww.. manu change your receiver and tv if the cable broke . buy brand new ones . dont forget to check with a doctor.,
nada...nobody asked you!...nobody cares what U say..Hawaian wasn't speaking to you/...learn some etiquette , U are a rude camel muncher, who should mind her own business!...now go walk the streets again and give some more head!
LK: Nobody asked you. Nobody cares if you are ignorant, because everybody know that. You are obsessed with camels - go speak to your psychiatrist. I WILL post where I want to . I have had enough of your interruptions. Now stop chasing me and go and learn about power supply of Pansat 3500s and also Viewsats.
LK: If you have taken to Islam, you go to Arabia not Afghanistan. That is my understaning. If there are any muslims in the forum, they would know better how to and when to go there. I do not know.
