Box tuning
Username: Spfld_b
Post Number: 11
alright i have 2 12'' ascendent audio arsenals. i really want them to hit the lows hard. should i tune them lower than the reccomended 35hz or should i keep it at that? also if i were to tune it lower would it have any negative effect on the sound quality or spl?
Username: Nd4spd18
Southeast PA
Post Number: 2019
Lower tuning = less SPL but better low end extension
Username: Spfld_b
Post Number: 12
how much loss of spl if say i tune it to 28hz? will there be a large difference in spl or just a slight difference?
Username: Nd4spd18
Southeast PA
Post Number: 2025
It would be noticeable compared to say a 35-40 hz tune. It would also play noticeably lower......
Username: Jkidder
Spring hill, Florida Usa
Post Number: 496
a good compromise a ton of ppl use is 30-33. i see that a lot.
Username: Spfld_b
Post Number: 17
so would i tell a decent difference if i tuned it to 32hz u think.
Username: Spfld_b
Post Number: 18
bump^ message didnt go up to the top
