Box is 95% complete!!!
Username: Hockeyknight
Post Number: 1090
its almost done!! i just gotta mount my sub (any tips???) and run the wire through!!!!! i got a few final questions tho.......
1 i dont have my alt yet but can i just wire it at 1 ohm and keep the volume down??? it would just be a pain in the as5 if i had to go back and wire it later....
2 ....nvm
Username: Dakangofkrunk16
PLANET EARTH, FLA
Post Number: 852
if the gain is set low also i dont see why not just make sure u dont egt ne voltage drops u got a volt meter
Post Number: 1091
ya i got a multi meter...how exactly do i check my voltage drop??
Username: Th3pwn3r
Post Number:...
Post Number: 2278
Take your DMM and measure at the amps outputs with the sub hooked up and play something and watch the voltage as you turn the volume up and just make sure it never drops below 12.5 .
Username: Nd4spd18
Southeast PA
Post Number: 2003
To check electrical system voltage you measure DC volts at the amp's power and ground INPUT terminals.
