Silver Member Username: Kenny_hammondPost Number: 211 Registered: Jan-05 | kicker or rockford fosgate in a small sealed box or jl audio subs i want it to be loud but not distorted! |
Gold Member Username: CtmikeCt. Post Number: 4086 Registered: Feb-06 | sounds like a pair of w6's is what you need. |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 432 Registered: Jan-07 | ^x2, but post your budget we can help to get better for the money, but jl is good, w6 and above IMO |
Silver Member Username: SplmonsterNowhere, OH USA Post Number: 758 Registered: May-06 | yea cant tell ya much without a budget |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1790 Registered: Jul-06 | JL is by far the best out of those for small sealed boxes. |
Gold Member Username: Denali_on_22sHit you in the chest m... Post Number: 2097 Registered: Feb-06 | How bout TC sounds? |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 4829 Registered: Jul-06 | beat me to it reece...ive heard most tc subs love small sealed |
Silver Member Username: Kenny_hammondPost Number: 212 Registered: Jan-05 | OK I AM LOOKING TO GET A PAIR FOR AROUND 500 AND THE BOX IS A SMALL SEALED BOX THAT GOES UNDER MY BACK SEAT OF MY TRUCK SO IT IS A REAL SMALL SPACE I THINK I WAS TOLD AROUND .65 OR MAYBE SMALLER |
Silver Member Username: Kenny_hammondPost Number: 214 Registered: Jan-05 | OK I WANTTO SPEND NO MORE THAN 500 A PAIR AND I THINK THE SPEC ON THE BOX IS .65 OR SMALLER FOR AIR I WANT IT TO BE LOUD AND DEEP BUT DONT DISTORT |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 556 Registered: Mar-06 | Well, JL may have a run for their money. The new RD Sonance woofers will be tested VERY soon. Kevin |
Silver Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 809 Registered: Feb-05 | I dont think your going to be able to get really loud. Your looking for 10's right? not 12's? I dont think a w6 would fit. What kind of truck? |
Silver Member Username: Kenny_hammondPost Number: 215 Registered: Jan-05 | IN A EXTRA CAB DODGE TRUCK YES 10'S I THAUGHT ROCKFOR WAS GOOD? BUT JL I S TO I AM LOST ON WHAT TO GET! |
Silver Member Username: Kenny_hammondPost Number: 221 Registered: Jan-05 | would ma audio be a good setup |
Silver Member Username: Kenny_hammondPost Number: 222 Registered: Jan-05 | DOES ANYONE KNOW? |
Silver Member Username: Smoke05Tucson, Arizona U.S. Post Number: 455 Registered: Jan-07 | for that space i would give a try of their TW5s |
Gold Member Username: Extrmndor3IF U HEAR ME... crazydbs.com Post Number: 4632 Registered: Feb-06 | pg subs http://phoenixphorum.com/12-subwoofer-test-idmax-flatline-pg-rsd-jl-w6v2-alec-vt 16.html |
Silver Member Username: Kenny_hammondPost Number: 223 Registered: Jan-05 | ok i am lost i am just looking for one type so i can go down and tell the local people to hook it up for me they all like jl audio should i just stick with that or tell them i want diff subs? |
Gold Member Username: Extrmndor3IF U HEAR ME... crazydbs.com Post Number: 4669 Registered: Feb-06 | pg will be louder than the w6 while playing clean as the w6 with alot less money man. |
Silver Member Username: Kenny_hammondPost Number: 224 Registered: Jan-05 | the ones that have the link above right will it play in .6 air space that is haow much i am going to have |
Silver Member Username: ReppinqcCharlotte, NC USA Post Number: 221 Registered: Jan-07 | ya go with w6's...you will be satisfied IMO |
Silver Member Username: Kenny_hammondPost Number: 225 Registered: Jan-05 | I THINK SO ALSO DO JL AUDIO HAVE GOOD COMPONETS ALSO? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1951 Registered: Jul-06 | The XR series are good |
Silver Member Username: DenimWww.TeamSSAudio.com, MD Post Number: 174 Registered: Nov-06 | Wow all these brands thrown out there with little mention of an actual model. Certain models are designed for small boxes, my personal choice would be an IDQ or Mach5 MAW. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1953 Registered: Jul-06 | ^^^^ Most all JLs can work in small boxes except the W7 |
Silver Member Username: ReppinqcCharlotte, NC USA Post Number: 248 Registered: Jan-07 | yea if you get a W7 i would high suggest putting it in a JL HO enclosure. |
Gold Member Username: Denali_on_22sHit you in the chest m... Post Number: 2196 Registered: Feb-06 | I mean it's hard to throw a model out there when he's not giving us how much power he's running. If you want a model number denim then I will say TC OEM 10's... Best bang for your buck, no doubt. After that I would recommend some TC 7's. |
Gold Member Username: Denali_on_22sHit you in the chest m... Post Number: 2197 Registered: Feb-06 | OEM 10 is recommended for .3 cubes for small sealed. I'm pretty sure you can handle that. Hell you could possibly go ported with these. They only need .5 cubes. |
Silver Member Username: Kenny_hammondPost Number: 226 Registered: Jan-05 | OK I AM GOING TO BUY MY AMP TO FIT THE SUB POWER AND I JUST WANT SOME GOOD SUBS AND MODEL SO I CAN BUY IT SRRY FOR THE INCONVENICE BUT I AM NEW TO THIS STUFF THE BOX IS AT SOUNDOFFAUDIO IF U WANT TO SEE DODGE RAM EXTRA CAB 10" BOX |
Silver Member Username: Kenny_hammondPost Number: 227 Registered: Jan-05 | anyone know |
