Whats the best amp for me??
Username: Millz025
Central islip, New york U.S.A
whats the best amp to use for 2 12 inch solobaric kicker L5s
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1501
Depends on the voice coil arrangement. If you have dual 4 ohm then you need 1500 watts at 1 ohm. If the subs are dual 2 ohm then you need 1500 watts at 2 ohms. If they are 2 ohm subs then get the Kicker zx1500.1. There are lots of amp options though. What is your price range?
Username: 420alldaylong
Post Number: 1541
L5 12" 600RMS 1200PEAK
Kicker ZX1000.1 will work fine I seen the same system about 2 weeks ago it sounded good for solo.
Post Number: 1542
If ther Dual 2ohm
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1503
sorry, i was thinking they were 15's for some reason.
