Did some research
Username: Kenny_hammond
Post Number: 229
Ok i got a lot better info on the box i am going with i am going to use a box that is # ir space = .6 CUBIC FT PER SUB
# Mounting Depth = 5.5 INCHES
# Speaker terminals included
# Charcoal Grey carpet
# Available in oem carpet colors to match your interior for an extra $25.00
# HOLE CUTOUT FOR 8 INCH SUB = 7"
# HOLE CUTOUT FOR 10 INCH SUB = 9 1/8"
the depth and hole size sort of screwed me does anyone have a good sub jl audio wont work i looked them up!!!!!!!!!!!!!
Username: Ctmike
Ct.
Post Number: 4152
idq.
Post Number: 230
? what does that meen?
Username: Ctmike
Ct.
Post Number: 4153
it's a sub: http://www.imagedynamicsusa.com/products_page.php?id=idq&type=sub
Username: Mike11202
DE US
Post Number: 423
Image Dynamics IDQ
Heres Dual 2 and Dual 4
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2032
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2033
Post Number: 231
will that be the best sub to get?
Post Number: 232
BX-DODGE10
BOXMEASUREMENTS
LENGTH 47 INCHES
BOTTOM DEPTH 14 INCHES
TOP DEPTH 10 INCHES
HEIGHT 11 INCHES
ENCLOSURE HAS 1.21 CUBIC FEET
OF AIR SPACE PER CHAMBER
SUBWOOFER MOUNTING DEPTH 7.25 INCHES
THIS BOX IS COMPUTER TUNED TO OFFER MAXIMUM BASS RESPONSE. CONSTRUCTION IS
INDUSTRIAL MDF 5/8" BOARD.
SPRING LOCK SPEAKER TERMINALS.
SPEAKER ENCLOSURE IS WRAPPED IN
GRAY COMMERCIAL CARPET.
THESE SUBWOOFER ENCLOSURES ARE HIGH QUALITY SEALED AND ABLE TO WITHSTAND
UP TO 2000 WATTS OF EAR POUNDING BASS.
ok i just found this box on ebay and just baught it so this is what box i am using what subs will fit in there the best will the w6's fit and sound good
Username: Ctmike
Ct.
Post Number: 4155
www.jlaudio.com
go there and see if they fit. no offense, but after numerous suggestions and you keep changing the box you're getting, bout time you do some searching yourself.
Post Number: 233
ok nevermind thanks for the help
Username: Loudon
Post Number: 997
i agree with ctmike ... ther idq is a solid woofer
