Which amp would be better?
Username: Allstar13
Houston, Texas
Post Number: 111
Rockford Fosgate T10001BD or HIFONICS BXi 2006D
i know the hifonics is overrated and that the rockford is underated.
so should i get the rockford since it better quality and probably puts out about the same watts
Username: Smoke05
Tucson, Arizona U.S.
Post Number: 479
the RF is expensier, but yes it puts around 1500 ( the only birthsheet i had seen for RFT1000BD), normally, they RMS is 1000 at 1, and the Hifonics is overrated, so it puts around 1600, IMO the RF is better, but if you are un a budget go with hifonics if you are looking for the power to be around 1600
Username: Kanishka
If you can go for a rockford, then that's it. it's very good.
I want to tell you some thing abt my experience.
I have a jeep and a car. i use rockford amps in my jeep and JBL amps in my car.
it cost me a lot for the rockford, but the quality is the same.
i have never used HIFONICS
Username: Smoke05
Post Number: 481
that is why JBL are nice amo too, Michael Adams post budget to get more options.
Username: Johnfiac
A-ToWn, 152-153db Da... My wangers b...
Post Number: 2466
JBL's older amps are sweet (from experience) THe moment i got a BP1200.1 i feel in love.... until i ended up seelling it the other week..... I still liked the amp more them a amp i have that does over double the power that one did..
Username: Nd4spd18
Southeast PA
Post Number: 1919
RF, that is no contest. More power and about 1000% better quality.
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2170
Ya'll act like Hifonics is dogsh!t nowadays. That amp (with a proper charging system) will put out around 1800-2000 watts and will cost half the money. The amps are still good quality as long as you supply the amp with what it needs then it was do it's job. With that being said, you will probably need a charging upgrade to get the 1500 watts from that RF amp. Am I saying the Hifonics is as quality of an amp as rockford makes? No. Will it put out more power than the T1001BD? Yes, more than likely.
Username: Allstar13
Houston, Texas
Post Number: 112
Which one is probabley the best deal?
http://cgi.ebay.com/ROCKFORD-FOSGATE-POWER-T10001BD-1000-MONO-CAR-AMPLIFIER_W0QQ itemZ320107078918QQihZ011QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ROCKFORD-FOSGATE-POWER-T10001BD-MONO-CAR-AMPLIFIER-AMP_W0QQi temZ270112340593QQihZ017QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/HIFONICS-BXi2006D-2-000-WATT-BRUTUS-BXi-2006D-AMP-NEW_W0QQit emZ150065935136QQihZ005QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://www.sonicelectronix.com/item_6523_Hifonics+BXi+2006D.html
Username: Nd4spd18
Southeast PA
Post Number: 1929
First one
Username: Allstar13
Houston, Texas
Post Number: 113
even with just the 3 month warranty?
Username: Allstar13
Houston, Texas
Post Number: 114
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 579
from my expirence RF is pretty power efficent they dont take much power to run them compared to the other ones ive used
