CDT audio or....
Username: Big_edge_head
Post Number: 74
i need to get new speakers for my car cause i just got two 12'' subs(AQ SD2.5s) and i need to know if these would be a good set up. or should i go with alpine or infinity? for the component set up front im not sure if i want to do that. i cant find any 4x6 speakers from CDT to go in the front, is there any kind of adapter to fit 6.5 speakers?
these in the front:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3059
these in the rear:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5435
Username: Skibum12189
Cleveland
Post Number: 504
what kind of car
Username: Alteraudiousa
Concord
Post Number: 1543
the KA series is a waste of your money. Atleast get the watered down CL series they have on sale from that site. If you are really interested in CDT also I can help you out depending on what your budget is. I would suggest using more money towards the front components and get an adapter for the 6x9 to fit a 5.25 CL coax instead if you needed rear fill at all.
