How to do aero ports....
Username: Quig
Pittsburgh, Pa Us
Post Number: 335
someone mentioned something about aero ports... im intrested but not sure how to do it, can anyone give me a link or help me out with it... heres the vented enclosure i was going to build for my mb quart 15" http://www.subwoofertools.com/forum/ported-box.asp?Ew=33&Eh=16&Dia=9&Xmax=18&Vd=
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2130
you need to get someone to do a design for you using aero ports... most people will make one for free of for about 5-10 bucks...
Username: Quig
Pittsburgh, Pa Us
Post Number: 336
do you know of anyone here that would do it for free? i would give some paypal cash, but my paypal is locked =\
Username: Quig
Pittsburgh, Pa Us
Post Number: 337
anyone ? =x
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 1066
How big of box do you want and what are your maximum dimensions and what would you like it tuned to?
Username: Matt12490
California USA
Post Number: 2262
What is the model number, and is it just 1 sub?
Username: Quig
Pittsburgh, Pa Us
Post Number: 338
http://woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3877
There is the sub... it will be only 1 of them, powering it will be PG octane r 15:0:1...
the reoomended sealed, is 1.5 cuft... orginally i was gonna build a vented enclosure but someone recoomended aero port, i never herd, or attempted to build one. but i want to... max trunk demensions are... 33"x16" not sure how deep, atleast 25"...and would liek it tune to 35 hz ...unless someone else thinks something different...
Username: Quig
Pittsburgh, Pa Us
Post Number: 339
Steinkea? come up with anything?
Username: Quig
Pittsburgh, Pa Us
Post Number: 342
up ^ please
Username: Quig
Pittsburgh, Pa Us
Post Number: 343
alright well it seems no one here can help me with the aero ports, so im just gona do vent...
Username: Adam_s
Post Number: 1079
Sorry I have been really busy. I can post something up for you later on tonight. Aero ports are a vented enclosure. Anything ported is considered vented.
Username: Quig
Pittsburgh, Pa Us
Post Number: 344
well, i ment not using pvp pipe, lol, like straight line, hard to explain... ok i will wait for you to post it up, you got all the info you need rite?
Username: Adam_s
Post Number: 1082
Here ya go. This should be 3 cuft tuned to 35 hz. The ports are 2 4 inch flared ports.
Username: M0nkeyman692
Post Number: 100
is there a difference in sound between those and a regular rectangular port?
Username: Quig
Pittsburgh, Pa Us
Post Number: 347
aright so i go to homedepot and tell them i need 2 4 inch flared pipes, 16.5" long and theyl no wat im talking about? and wehre exactly shuld these ports be places, like how many inches shuld they be seperated from each other? thank you sooo much steinka for the help.
Username: Adam_s
Post Number: 1084
Sorry didnt get back on until now. Home depot will not have flared pipes. You can get them from
http://www.psp-inc.com/psp-inc.com/public_html/4%20inch%20precision%20ports.html
or else you can try parts express. You will prolly have to cut them to the length you need. If you decide to go to PVC ports you have to subtract one inch from the length of the port.
Username: Th3pwn3r
Post Number:...
Post Number: 2262
Rick it sounds as if you don't know exactly how to do this.You should have a box built for you and then work on building your own to see how it's done.The good thing about this would be that you get to bump and work on your own box without ever being without a system :-)
Username: Quig
Pittsburgh, Pa Us
Post Number: 349
ahh im so confused... when you say if i use pvc ports subtract an inch? so i would get 2 pvc pipes 15.5 inches long? and can i use pvc pipe instead of flared pipe, will there be a big sounding difference?
Username: Adam_s
Post Number: 1089
Yes the PVC pipes would have to be 15.5 inches long. There really wont be noticeable different between the flared and PVC ports. Flared ports are easier to mount than PVC though.
Username: Quig
Pittsburgh, Pa Us
Post Number: 350
ya i can visually see that lol flared all you do is pop them in and seal around them while pvc, will take soem good cutting and sealing job... umm one last question, how far should the ports be away from each other and the bottom/top box, and i say i need 2 4" 15.5" long pvc pipes theyl no wat im talking about rite? thanks for all your help, steinkea.
Username: Adam_s
Post Number: 1092
It doesnt really matter where the ports are located. Just try and get them in a spot where it looks good. At Home Depot you will prolly only be able to get full lengths of PVC pipe and will have to cut them down I am not really sure you will have to check with them.
Username: Quig
Pittsburgh, Pa Us
Post Number: 353
is there a program that tells you the exact cut outs of the mdf u need for sealed boxes... because im stupid when it comes to geting the exact cut outs...
Username: Adam_s
Post Number: 1094
No offense but I have a feeling you are gonna mess this up. I really think that your best bet may be to actually buy a box.
Username: Quig
Pittsburgh, Pa Us
Post Number: 354
ive built 3 boxes.. 2 sealed and 1 ported... not aero ported tho..its aright ill figure it out...
Username: Adam_s
Post Number: 1096
The aero ports dont matter anything to how the box needs to be built. You just have to build the box to the dimensions I listed and cut holes for the ports put them in and be done w/ it. I have calculated everything out for you already.
