New member Username: RyanrafiePost Number: 1 Registered: Apr-07 | Hey wats up, I have a jl 13w7, with a kac - x1r amp, http://www.speedsound.com/product.asp?specific=jokpfrnno . I have my 04 Cadillac Deville Head Unit. My dad has the hook- ups at kenwood so if you could recommend some head units from there please. Also just throw out some headunits you think would be better. I'm looking for somthing that will make my sub better, and something that tight. Thx. |
Gold Member Username: Van_manBoston South, MA Post Number: 2341 Registered: Mar-06 | this http://www.kenwoodusa.com/products/ListProduct.aspx?k1=2&k2=46&k3=172&pr=2739 |
New member Username: RyanrafiePost Number: 2 Registered: Apr-07 | lol i was trying to get that but there back ordered, should i wait till they get more or does kenwood have somehting better? |
Gold Member Username: Van_manBoston South, MA Post Number: 2345 Registered: Mar-06 | Wait for it. Its the top of the line Kenwood makes. It also has a internal hard drive so you can rip cd's directly onto it. Not much storage only 512 MB storage. Or look into the X891 It has a USB so you can use a 4 gig thumb drive on it. |
