What amp to but
Username: Kenny_hammond
Post Number: 238
what size amp should i buy for two w6's
Username: Liqdfire3
Lee high acres, Florida
Post Number: 204
dual 4 ohms? dual 2? this information helps alot.
Los Angeles, CA USA
Post Number: 12470
jl 1000/1 would work nice for those subs. if you don't want spend that much then kicker kx1200.1 if they can be wired to a 1ohm load or kicker zx1000.1 if they can be wired to a 2 ohm load.
Username: Th3pwn3r
Post Number:...
Post Number: 2325
You can also look into amps from Elemental designs.If you're on a really tight budget look into Hifonics but I personally don't like their lower lines all that much.
Username: Dakangofkrunk16
PLANET EARTH, FLA
Post Number: 1032
hornetsnest2k3@yahoo.com email him he can get you a good deal on the Jl or kicker dunno about ED tho tell him Dakang sent you
