Silver Member Username: Holt_champHtown, MI Post Number: 772 Registered: Oct-06 | ok so i was gonna give my friend my old panisonic head unit but his impala's original wires dont say what they are...its a 2002 impala and it still has the stock cd player in it. does anyone have a clue what colors could be what??? please help with any info. |
Bronze Member Username: Sicknt760Apple valley, Ca Usa Post Number: 29 Registered: Jan-07 | you should just get the wiring harness that goes with that car instead of hackin up all of the wires |
Silver Member Username: Holt_champHtown, MI Post Number: 774 Registered: Oct-06 | what is a wiring harness and how can i get one?? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 2594 Registered: Jul-06 | Go here and put in the info about the car, then look under installation accessories or wiring or whatever: http://www.crutchfield.com/S-UFrCMNMtNaQ/cgi-bin/autoinfo/autoinfo.asp?lp= |
New member Username: Krs_onePost Number: 4 Registered: May-07 | you can get a harness at most autoparts store and bestbuy and car audio store |
Silver Member Username: MmaudioconceptsMurray, KY Post Number: 246 Registered: Jan-07 | you can get one at walmart cheap |
Silver Member Username: Holt_champHtown, MI Post Number: 779 Registered: Oct-06 | ok so my friend went and asked about aa wiring harness but thry told him he cuoldnt put a cd player in his car because of some message center that was connected to the headunit? is that true or are the ppl at the audio place just retarded? |
Gold Member Username: DelsolePost Number: 1270 Registered: Feb-05 | i would say that they are retarted because you can put an after market unit in just about anything, but then again im no professional. |
