Trying to build/tune a box, Any help please???
Username: Sinful_systems70
15 INCH WANG...
Post Number: 786
I have a JL Audio 15W3v1 and I want to build a box for it this weekend. It will be 3.5 cu.ft. ported. What should I tune the box to when using this sub? I am looking for something in the middle, SPL and SQ. So SQL I guess but I want it to sound good but still have good SPL. (Sub up, port back is what it will be if that will make a difference in tuning). What is an average or good tuning for my application? Thanks in advance..
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12191
30-32hz would be nice...maybe even a lil lower
15 INCH WANG...
Post Number: 788
This enclosure is tuned to 29hz. Would this be good? How do you compensate for driver displacement? The black area is the port. The opening of the port is 1.25" and the port ends 1.25" from front of box.... Upload
15 INCH WANG...
Post Number: 789
bump
15 INCH WANG...
Post Number: 797
bump one more time..
Username: Matt12490
California USA
Post Number: 2272
I don't understand the picture.
15 INCH WANG...
Post Number: 800
What don' you understand? I apologize for the black on the side. The port faces you in the picture.
15 INCH WANG...
Post Number: 801
Upload black = port opening and circle = sub opening
Username: 420alldaylong
Post Number: 1519
Try this out.
http://www.subwoofertools.com/forum/ported-box.asp
15 INCH WANG...
Post Number: 812
Will this be good? bump
15 INCH WANG...
Post Number: 815
Why won't anyone answer? What would be the best tuning for box for this sub in a trunk? I want to start building later today... Anyone think this enclosure above is good? Is the port to big/wide? It is only 1.25 inches of an opening but it will be roughly 32" wide... Any coments please... Chad Lee???? Chauncey????? Logan????? GW????? Anyone?????
Post Number: 1555
http://mobile.jlaudio.com/pdfs/15_18_W3_MAN.pdf
Username: Skies
Courtenay, British Colu... Canada
Post Number: 626
I would think there would be a noticeable amount of port noise with such a small port. That's merely a guess though.
Someone more experienced would be able to tell you for sure.
Username: Wolf_hound
Post Number: 183
build this one it will be louder its according to specs http://www.subwoofertools.com/forum/ported-box.asp?Ew=32&Eh=12&Dia=9&Xmax=17.1&V d=0.140&NumW=1&Vb=3.5&Fb=30&Qts=&Vas=&Fs=&CE=0
