Dd 3515 or Fi Bl 15"
Username: Killswitchjd
Post Number: 441
SQ vs SPL vs SQL???
any input is apreciated. I was going for the bl, but i have heard so much good about dd. Also how much is the dd 3515? Thanks
Username: Northomaha
Post Number: 300
i believe the dd is upwards of 600 a piece, could be wrong tho, thats just what i heard
Post Number: 444
really? If thats true this thread can die, because i will get the bl instead by cost for sure
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2116
You can get a 3515 for less than 300 shipped depending on hornet's nests prices... contact jordan singleton or ben or a couple others for information... it was 250 shipped last time i checked, and i would go with the DD over the BL
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1035
Hey...I am pretty sure you contacted me a while ago. Did you ask Ronnie about it? He can get you those for a lot cheaper than $600. Let me know if you need more info again.
Ben
b_schwanz06@hotmail.com
Username: Mgbcs
Lincoln, Nebraska
Post Number: 1036
Bump damn it!
Username: Nd4spd18
Southeast PA
Post Number: 1826
35 series are about $400 direct from DD
And 35 series > BL
IMO
Post Number: 446
specific sq/sql/spl please...
between the following if possible:
sq:
jl 13w7
Fi Q 15"
dd 3515
Spl:
Fi BL 15"
dd 3515
had to throw the 13w7 in becasue alot of people still say its the "best"
Username: Cashby
12 Fi Q
Post Number: 312
so wait that dd 3515 is only 250 shipped and you guys say it gets louder then the BL...how much can that dd hold for power anyway??
Username: 420alldaylong
Post Number: 1498
Don't forget about AudioQue HD3 15" $379
Post Number: 1499
Cody Scott
Where can you get the DD3515" for $250
Username: Cashby
12 Fi Q
Post Number: 313
Joey wat about a hd3 12"?? wat can u get that for..?
Post Number: 1500
http://www.audioque.com/aq/index.htm
Username: Cashby
12 Fi Q
Post Number: 314
wat...? does anyone no the exact price of a dd3515??? or a 12 is better??
Post Number: 1501
From a dd dealer around $400
Username: Ctmike
Ct.
Post Number: 4092
$365 plus shipping from dd for the 3512. not sure on the 15".
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4503
DD is better but i have to say, you don't loose to much quality or output by using a BL instead of 3515. I mean DD is superior but the difference is not that BIG if you understand what i'm saying
Username: Nd4spd18
Southeast PA
Post Number: 1831
1600 watts is good for a 35 series
Username: Reppinqc
Charlotte, NC USA
Post Number: 194
yea im in the same boat, debating on what single 15" sql sub to get...from what everyone says ill prolly go wit the dd3500
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1670
depends on power. a 3515 would b closer to a BLwith the upgrades. 3515s will take 2k-2.5k if u keep it clean.
Post Number: 449
so which would be better with a Ed nine.1?
Post Number: 450
3515 or a fi Bl loaded 15"
Username: Reppinqc
Charlotte, NC USA
Post Number: 197
so would i be good if i got a DD3515 and then a Sundown 1500 (or similar amp). Then once i upgrade my alternator, and possibly get a battery and do a big 3, i could add another 1000 watts to it?
Post Number: 2140
i would go 3515... it's more efficient (gets louder on less) and can handle more power...
Username: Reppinqc
Charlotte, NC USA
Post Number: 203
ok this is a stupid question i know but could i get a large enclosure for 1 DD3515 and power it with 1 sundown 1500w amp then after i to a H/O alt get another hole cut in the enclosure for another dd3515 and just add another sundown 1500w amp to it?
Username: Nd4spd18
Southeast PA
Post Number: 1901
Sure, if you build a separate chamber box as opposed to a common chamber. Then you can run it with just one sub until you get 2.
Username: Reppinqc
Charlotte, NC USA
Post Number: 205
ok thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12181
Fully loaded BL>3500
Stock BL<3500
Username: Reppinqc
Charlotte, NC USA
Post Number: 206
Chauncey are you comparing these in SPL,SQ, or SQL?
