Bronze Member Username: Justin_15_07Manitou Beach, Michigan United States Post Number: 39 Registered: Apr-07 | I have 2 lt1920 watt amps wiring to 2 audiobahn utlra high excursion aw1005W. I have them both almost all the way turned up and i just wired them this way and on the way to work i noticed a bad electrical burn smell. I cant tell if its coming from my subs, which is seems to be the strongest out of the port in my box, or if its wire burning, my ground cable terminals that are grounded to my car are HOTT but dont seem to be giving off the smell. I have both of my amps grounded to the same spot, is that the problem or what should i do please help |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11996 Registered: Dec-03 | insufficient wire gauge or not a good enough connection to ground, causing the amps to clip (also can be lack of adequate current for amps that big) causing the amps to clip, causing the sub voice coils to burn up. |
Bronze Member Username: Justin_15_07Manitou Beach, Michigan United States Post Number: 40 Registered: Apr-07 | so i should clean the grounds really good, my positive wire is not hot at all, should i wire my grounds in different places? |
Gold Member Username: CarguyPost Number: 6157 Registered: Nov-04 | You need to set the gain/level properly before your amp/sub burns out. If the power wire is getting hot, you need a thicker wire. It's a sign that you're drawing too much current on a thin wire. |
Bronze Member Username: Justin_15_07Manitou Beach, Michigan United States Post Number: 41 Registered: Apr-07 | k so ill turn my level down on each amp till i get my 0 gauge wire in. The wire is only burnt on the terminals connected to my car, then after i get that wire can i turn my level back up? is it also back to ground both amps to one ground? The wire is only getting hot at the ground terminals, no where else. |
Gold Member Username: CarguyPost Number: 6160 Registered: Nov-04 | With 0 gauge wire, it shouldn't get hot at all. There's no way your car can supply enough current to overheat/melt it unless you have a short. Don't set the gain to max, you'll blow the amp. Read the manual and set it according to your HU. |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1800 Registered: Jul-06 | And if the smell came from the port, the subs voice coils are most likely damaged already |
Bronze Member Username: Justin_15_07Manitou Beach, Michigan United States Post Number: 43 Registered: Apr-07 | k but is it bad to wire both grounds from the amps to the same ground bolt on my car? |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1838 Registered: Jul-06 | NO |
Bronze Member Username: Justin_15_07Manitou Beach, Michigan United States Post Number: 44 Registered: Apr-07 | and my amp doesnt have a gain or anything, it has level sub sonic, bass boost, HPF, and LPF |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1861 Registered: Jul-06 | Whoa, hold on there. All amps have a gain setting, "Level" is another name for gain. You need to set that properly, use these instructions: http://www.subwoofertools.com/forum/setgain.asp You probably had it cranked way up and were clipping the subs. |
