Bronze Member Username: XarnixUSA Post Number: 19 Registered: Oct-06 | Hi guys, I got Pansat 2700A and Satallite Dish. I dont have an LNB. My question here is what kind of LNB do I need to get in order for me to have all the PPVs, Sports channels, FOX Soccer. etc. And what kind of Satelite I need to scan in order for me to get those channels. I belive Echo7 but Im not sure. PLS HELP SOMEONE. |
Gold Member Username: LklivesPost Number: 9033 Registered: Jan-06 | Go READ! |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 1837 Registered: Nov-06 | Dp duals are my fav.Very versitile and dependable. |
Bronze Member Username: XarnixUSA Post Number: 20 Registered: Oct-06 | LK. READ WHAT. THERE IS NO TOPIC HERE ON THIS SUBJECT. SO YOU EITHER HELP ME OR YOU DONT. |
Bronze Member Username: XarnixUSA Post Number: 21 Registered: Oct-06 | Im only looking for one LNB. which one should I have? |
Silver Member Username: RtapFL Post Number: 196 Registered: Jan-07 | get a dish pro 500 it comes with both 110-119 lnbs.once installed makes sure you have signal then scan echo7 and echo 8/10 you should be ok. |
Bronze Member Username: SatscannerrPost Number: 32 Registered: Apr-07 | ARNI dont listen to this loosers. what kind of dish you have . does it have any logo ? so i can tell you what to do to get both sats 110 that has lot of ppv and fox sport and 119 has the rest of programming . |
Silver Member Username: RtapFL Post Number: 199 Registered: Jan-07 | satscanner was i wrong in my advice |
Bronze Member Username: SatscannerrPost Number: 33 Registered: Apr-07 | sorry : just to be clear (Dp duals are my fav.Very versitile and dependable) DP DUALs are my favorite: i meant double penetration |
Silver Member Username: RtapFL Post Number: 201 Registered: Jan-07 | satscanner was i wrong with my suggestion. |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 1850 Registered: Nov-06 | cartier's off his meds,ignore him.[fake satscanner]He just wishes he was me! |
Silver Member Username: Crazy_greekPost Number: 889 Registered: Jul-06 | Hey RTAP NO,you was not Wrong. |
Bronze Member Username: XarnixUSA Post Number: 22 Registered: Oct-06 | Satscanner there is no logo on the dish. its a pretty big one, bigger the the regular dishnetwork ones. well, Im looking for LNB for 110. What kind should I get |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1076 Registered: Oct-06 | "pretty big one" If you play with your LNB it will get pretty big that is normal I assume it is the twin LNB for 110/119 You can get both birds with one coax wire Set each sat to a DISEqC port Scan one Sat at a time |
Bronze Member Username: XarnixUSA Post Number: 23 Registered: Oct-06 | Hey guys, I'm not looking for a twin LNB. Im looking for a single one LNB just for the PPVs. Which LNB should I get. I have a friend he has Pansat 2700A on 110 with one LNB. But he doesnt know what kind of LNB he is using. Therefore Im asking you guys to help me out to see what kind of LNB should I get for EchoStar 7. |
Bronze Member Username: ShadycovePost Number: 58 Registered: Sep-06 | hi...hopein i can slip in a lil question witout gettin yelled at....i know i would need a diseqc switch to use multi lnb,but what do i need to just run 2 recievers off my one dish....sorry to be so dumb.... |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1077 Registered: Oct-06 | Arni Circular Dual LNB (one LNB with 2 outlets) for 110 Twin LNB (2 LNBs with 2 outlets) for 110/119 Same for you BetterOffRed 2 outlets (1 for each receiver) |
Bronze Member Username: ShadycovePost Number: 59 Registered: Sep-06 | thanx.... |
Bronze Member Username: XarnixUSA Post Number: 24 Registered: Oct-06 | Thanks King Tapeman, The Dual LNB is from Dishnetwork LNB right? |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1078 Registered: Oct-06 | Yes from DN This is the Twin quad Twin dual looks like the twin quad with 2 outlets What is nice about it is one wire needed for each receiver very easy to use |
Bronze Member Username: XarnixUSA Post Number: 25 Registered: Oct-06 | where do I can buy the dual or twin LNB. do they sell in bestbuy or radioshack. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1079 Registered: Oct-06 | Twin dual you run one coax straight to receiver No switch needed Twin has internal switch I recommend you use RG-6 check this section for wirring https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1080851#POST1080851 In antenna setup: 110 DISEqC port-1 119 DISEqC port-2 Scan each Sat seperately one at a time Twin LNB You can pick one very cheep from e-bay or google for Satellite website |
Bronze Member Username: XarnixUSA Post Number: 26 Registered: Oct-06 | thanks KG, So you are saying if I use dual LNB I dont need switch. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 1080 Registered: Oct-06 | That is correct |
