Bronze Member Username: Xfacta82Post Number: 70 Registered: Mar-07 | http://www.hookedontronics.com/show_product_details.jsp?cid=18714 Is this a good head unit? |
Gold Member Username: CtmikeCt. Post Number: 4089 Registered: Feb-06 | yes. |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 517 Registered: Jun-06 | for 10 more dollars you can get all the install parts at sonicelectronix for that head unit |
Bronze Member Username: Xfacta82Post Number: 71 Registered: Mar-07 | What are the install parts? Do i need them if im having a store install it? |
Silver Member Username: The_image_dynamicSan Diego Post Number: 926 Registered: Dec-06 | That would be the mounting kit and the wiring harness. And yes you need them if you are going to have it installed. Those are exactly the specialty items that install shops love to jack you up on. Sonic can be trusted too. Make sure you call them first to make sure that they stock the install parts for your particular car. |
Bronze Member Username: Xfacta82Post Number: 72 Registered: Mar-07 | Does the other website not include them? |
