Neosat iPRO 1000
Username: Angelo921
Post Number: 8
Is it true that the Neosat iPRO 1000 does not need any BIN files ever? After buying it does it need any software installed on it or is everything already installed on there. It says here just plug it in.
http://www.extremesats.com/ipro1000.htm
thanks
Angelo
Username: Wes_w
Post Number: 8
Hi Angelo,
Currently the bins need to be downloaded for the 1000, and sometimes the keys manually entered. Once Iks is back up for the ipro 1000 it should be working again. The Neosat Ipro 2000 does have the IKS and eathrnet loading going, it also adds PVR via and external HD, it is a pretty impressive receiver at a reasonable price.
Hope this helps
Username: Wes_w
Post Number: 9
Just to add the ipro 1000 is out of stock, i don't know if you can get ahold of on as is an older receiver, but on that same site click on the left side for ipro 2000.
Visit Ftalife for information on hooking up bin files and free freindly support
Link is in my profile
