Question about Dual LNB
Username: Jayson
Post Number: 20
In a standard dual LNB, can I connect one receiver to one of the connectors and another receiver to the other??? Of course I know I can connect them. The question is if I can do that and watch programming on both receivers or do I have to do something else to make this work. Thanks in advance.
Username: Lklives
Post Number: 9301
The dual LNB receives 1 satellite signal with 2 outputs for 2 receivers...so each receiver will operate independently of the other, but receives only 1 satellite signal on each receiver..
Username: Jayson
Post Number: 21
I'm asking cause i tried to do that but the second receiver does not have any signal at all, so I can watch TV in only one receiver. Any ideas??
Username: Lklives
Post Number: 9304
bad cable
bad connection
wrong keys
bad settings
bad port on LNB (least likely)
receiver needs reboot ( power off/on by rear switch)
etc..
Username: Lklives
Post Number: 9305
now just start doing things to do a process of elimination..
Username: Jayson
Post Number: 24
Thanks LK.......the problem was the cable.....there's a big dufference between using an RG-59 and RG-6 cable.....
Username: Jayson
Post Number: 25
Thanks LK.......the problem was the cable.....there's a big difference between using an RG-59 and RG-6 cable.....
Username: Lklives
Post Number: 9363
congtrats on fixing it..yes RG6 has always been recommended for satellite TV, never RG59, which cable TV uses....
