Gold Member Username: Matt12490California USA Post Number: 2246 Registered: May-05 | I got a new headunit that I want to use with my iPod, but don't know which would be best to use. It has an AUX plug in the back and also one for an IP bus but don't know which would be better. http://www.sonicelectronix.com/item_7576_3.5mm+6+ft.+Extension+Cable+for+iPod+-+ MP3+Player+headphone+jack+to+aux+input+or+another+headphone+jack.html or http://cgi.ebay.com/CD-IB100II-CD-IB100-iPod-Interface-Adaptor-for-Pioneer_W0QQi temZ300103147691QQihZ020QQcategoryZ58350QQcmdZViewItem Would they both give me the same sound, or should I shell out the extra cash for the expensive one? |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 4084 Registered: Jan-06 | really it all depends the second one looks like it will also charge your ipod. i doubt by ear you will hear much difference in the two |
Silver Member Username: RiskybPost Number: 605 Registered: Feb-06 | Well the auxillary won't charge your ipod but you can go buy one at like radioshak or walmart for like 4$. The ipod one is better I guess, you get better SQ too. I use the Aux myself because I don't like scrolling through my huge library on my headunit. |
Bronze Member Username: M0nkeyman692Post Number: 55 Registered: Feb-07 | dont bother getting the ip cause scrolling through your headunits screen is a pain and since ipods are so portable it just as easy to take it inside when it needs to be charged.. |
Bronze Member Username: Dakangofkrunk162Post Number: 50 Registered: Apr-07 | CD-IB100II CD-IB100 iPod Interface Adaptor for Pioneer i ahve that and u do get better sound quality cause it is goin thru ur dock yea u mite have to scroll but u can also just unhook ipod find song and hook it back up ALSO If ur ipod isnt updated or it mite strill work it stopped for mine tho turn ipod on play song pause it let it go to sleep on its own takes a min or to hook it up to car turn car on and turn ipod on it should elt u scroll thru the ipod and pic a song dont get mad at me if it doesnt work idunno if it iwll work anymore u either need to hook ipod then turn car on or tunr car on then hook ipod |
Gold Member Username: Matt12490California USA Post Number: 2247 Registered: May-05 | I think I'll just get the AUX cable first, and might get the ip bus when I have more money. Also, I already have a car charger for my ipod so its not a problem. |
