Amp under 250
Username: Legacyaudio
Post Number: 195
around 1000w rms at 2 ohms... any help.. the 250 is with shipping if at all possible
Username: Nd4spd18
Southeast PA
Post Number: 1751
The cheapest 1000 watt amp of decent quality that I know of is a Hifonics 1206d:
http://cgi.ebay.com/HIFONICS-BXi1206D-Class-D-Mono-Amplifier-Amp-BXi-1206D_W0QQi temZ300101882003QQihZ020QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Those amps are a little overrated so that one should do about 1000 watts.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4464
M.S he needs 1000w rms at 2 ohms not 1.
Legacy, try kicker zx 750.1 or jbl gto1201.1
If those are too high, then try Power acoustik a 1800db. That will work too
Username: Nd4spd18
Southeast PA
Post Number: 1764
Aw dam,
didn't see that. Yeah look at the amps juliob posted. But I would definitely go with the kicker or JBL over a power crapcoustik.
Username: Juliob
Post Number: 4475
yeah.. the PA is the last choice, if you can't afford a good amp. If i were you, i'd wait and save at least 30-50$ bucks more.
That way you can grab 1000w rms with quality
Username: 420alldaylong
Post Number: 1484
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12983
