Best bang for the buck surround sound
Username: Cutlassaapower
I have future plans in setting up surround sound and am looking for suggestions on the best bang for your buck.
My budget is around $300, but Im willing to go higher
Username: Project6
Post Number: 13992
Whole system or just receiver?
Define your willingness to go higher.
Username: Mccambley
BREEZY POINT, NY USA
Post Number: 354
If $300 is for the total for an entire surround sound sytem don't waste your money.
Username: Eib_nation
Ohio EIBville
Post Number: 178
Maybe a boom-box is what you want?
Username: Deadhorse
Post Number: 81
Go on ebay and look for a used system? You'll only be buying a receiver and speakers they'll either work or the seller will have to say they don't.
Just be sure to check the S&H before you buy, could be pretty heavy.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 88
Even just for a receiver $300 isn't going to get you very much.
Username: Deadhorse
Post Number: 82
Don't know where you're getting the $300 from but if you could come up with another $150, the Onkyo HT-SR800 system's pretty sweet for only $450.
Check it out.
