Need help on what power supply needed
Username: 20inchchoppaz
Frankfort, Ky
i have 3 kicker comp vr 15s wired in 1.3 ohms..its my first big system, so i need help on what kinda power supply i need as in a 2nd battery,capacitor, or whatever else i need..please help
Username: Nd4spd18
Southeast PA
Post Number: 1866
First of all capacitor = waste of money
Next, with a 1500 watt system you won't need extra batteries.
You probably will need an HO alternator. Make sure to get one with good regular amperage and idle amperage ratings. I recommend these companies:
http://stores.ebay.com/Iraggi-Alternator-and-Electronics
www.ohiogen.com
Username: Nd4spd18
Southeast PA
Post Number: 1867
And of couse the big 3 needs to be done when installing the alternator:
http://www.the12volt.com/installbay/forum_posts.asp?TID=73496&PN=1
Frankfort, Ky
Post Number: 7
aight man thanks alot with all the help glad i join this place cuz caraudio.com dont know crap
Username: Adddisorder
West palm, Florida
Post Number: 4101
yeah ca.com sucks another great forum is http://com4.runboard.com/becousticsfam
Username: N2audio
Lawrence, Ks USA
Post Number: 1272
honestly, without knowing what amp you're planning to use there's no specific info we can give you.
If you use a 1000w class d amp (1000w at 1 ohm) most any stock electrical system should have you covered.
A 1500w class d - most modern charging systems with a 110-140A alt should do it w/o a lot of trouble.
If you're thinking 2000w, or 1000w high current a/b you should probably start shopping for an HO alt alt.
Do you know what your stock alt is?
Do you know what condition your battery is in?
If your alt's decent size, and your batt's in good shape I wouldn't do much, personally. Maybe check for any obvious corrosion, or obviously undersized wires (alt to batt, batt to chassis, chassis to block)...otherwise - install it, see how it runs, make changes if you need them.
Frankfort, Ky
Post Number: 9
my stock alternator is about 90watt and my battery is i think a couple of months old and i have a optima battery in the rear for my last system i had but i dont know what the amperage is on it
Username: N2audio
Lawrence, Ks USA
Post Number: 1273
90A isn't a big alt, especially if your car has a lot of stock electronic options.
You might want to see what is available as far as an alternator upgrade
Username: Glasswolf
Wisteria, Lane USA
Post Number: 12003
http://www.betteraudio.com/geolemon/newmain/battcapalt/
Username: Waterboy2289
Georgia, DiRtY SoUtH ... 2 18 SX w/ ...
Post Number: 310
Since you already have an extra battery in the back, I would just do the big 3 upgrade(with 1/0 wire) and definately use 1/0 wire for your amp. You should be fine with that for ~1500w of class d power. When picking an amp, definatley do class d.
