Anyone with a pansat 2700 working?
Username: Chrisduclo
Post Number: 27
what boot file?
what bin?
is it possible to down grade boot file?
Username: Lucia
Post Number: 347
i ask the same thng... ??
anyone?
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 1707
To down grade a pansat? There is nothing lower than a pansat!lol
Username: Lucia
Post Number: 351
satscanner why r u here anyway?
had anyone ever told u
U DONT HELP!!
Username: Maryvazq
Puerto Rico
Post Number: 583
Mine is working (NOT THE AUTO ROLL) but with manual keys. Last bin with boot 75
Username: Nimesh
hi hi have a pansat 2700a receiver and i put in the new keys and save them turn off the receiver for a minute and turn it back on it works fine for a few minutes and then the picture stops and it goes back to waiting for picture.
when i go back and see the keys are changed and i have to reenter them and it works for a few minutes and repeats the poblem
someone please help
thanks
nimesh
Username: Hardrockstriker
Post Number: 740
Nimesh, keep your autoroll OFF.
Username: Nimesh
thanks jason but when i turn the autoroll off then i do not get the picture at all and then i have to turn autoroll back on to get the picture
but after a few minutes the keys get screwed up and it goes back to waiting for picture
thanks
nimesh
Username: Mc_sunny
Post Number: 1196
AutoRoll fix for Pansats 2800, 2700 and the 3500...click on this link to get the new files
http://www.marketrealm.com/private/forumdisplay.php?f=10
Username: Bvvenegas
hello im new at this i have a pansat 2700a and when i turned on my pansat today it said waiting for picture what do i need to do to get my pansat going again?
Username: Thunder_lightning
Post Number: 216
humberto you need to enter new keys...
DN keys- Updated: 16:00 04-11-07
(Key 86) B8 46 82 2D 29 B6 25 87 8C B1 63 15 24 65 0D 8A
(Key 96) 53 B1 5A D5 D0 FD 53 8C 6F 19 5F DE BF 78 80 8E (Active)
Bev keys Updated: 13:53 04-11-07
Key 0 - 36 F1 D3 FB 76 4F A6 88 83 74 3F E9 CB 12 9C 5B
Key 1 - D4 94 A2 33 DD 93 91 96 ED 3C 27 59 8E 55 90 C0 (active)
Username: Bvvenegas
can anyone tell me how to enter the keys because it my first time and i dont have a clue
Post Number: 218
first go to meanu..parental control..second pin enter 0000...than u will see the page say SECA..go down to autoroll option press ok...leave the keycode to ON...and the last 3 turn it to OFF....that mean u have turn off your autoroll....now exit it all the way out to the screen than follow this to enter new keys....
Pansats:
1. Hit the Menu button.
2. Then scroll down to Parental Code, and hit "OK".
3. Then go to Second Pin and enter all zeros. (0000)
4. Now scroll down to Nagravision 2 and hit "OK"
5. On Provider ID, select the Provider you need, Dish Net, or Bev.
6. Move down to Key Number. Depending on what key you need to enter, you will change the key number by using the left or right arrows only. Key 86 is the same as Key Number 00, and Key 96 is the same as Key Number 01.
7. At the bottom of the page it will tell you which buttons to use to get the
appropriate letters for your keys.
8. Once you have changed the necessary keys, hit the "OK" button and make sure that the "OK Store" words blink at the bottom right corner.
9. Exit all the way out of your Menu, and change channel.
10. Watch TV.
Username: Omen_2
luciaa.....satscanne is only here to run up his post numbers with his BULLSHIT
Username: Bvvenegas
thank you thunder you helped me out alot and i really apprecieted it.
Username: Nydas
Post Number: 2344
nimesh :
1. You must be 100% sure you have a genuine Pansat 2700A/E receiver. Go to Pansatusa site to check this if you have to.
2. From today onwards, you WILL need B75 boot and the latest BIN on top. There is a new BIN out today. The al7bar site has good instuctions.
http://www.totalfta.com
http://www.dssrookie.com
Username: Lovermexican
hello i have been putting the codes and they dont work just wondering if i have a subscription to dish already and i just connect my pansat while the dish one is on does it affect it cause i still get nothing
