LK need help
Username: Bouttep
Post Number: 36
my pansat 2500 a keeps on turning off and rebooting
any advice
thanks
Username: Lklives
Post Number: 8796
try another bin...cause some do that, some don't...and provide more info...there are many posts here telling u which bins do that and which don't..READ!!!!....hint-288
Username: Bouttep
Post Number: 37
i have the 293 bin , i will try another one and i will let u know thanks for your help
Username: Bouttep
Post Number: 39
lk
i tried the 288 bin it worked for a few hours then it started doing the same thing all over again ( rebooting over and over) any suggestions
thanks
Username: Lklives
Post Number: 8840
I would clean out the receiver memory with a factory reset, then factory bin, then input antenna dish settings again, rescan the birds, reboot the receiver and input the 293 and let the keys autoroll..or use the 288 and autoroll off, and input latest keys.
Username: Bouttep
Post Number: 40
thanks for the info lk
what would we do without u
i'll let u know how it goes
Username: Bouttep
Post Number: 41
lk i did everything you said , and i'm still facing the same problem 3 hours later , i even loaded a boot60 file , then 224 bin then the 293 bin and still after a while it freez's then shuts off and on again
any more suggestions
thanks
Username: Bouttep
Post Number: 42
lk
i did everything you suggested , but i still have the same problem.i even loaded a boot60 , then a 224 bin , then a 293 bin but a few hours later it starts shutting off and he on
thanks
Username: Lklives
Post Number: 8995
I would do the same , then use the 288T bin..remeber u will need to shut off autoroll, and manually input keys (no big deal)...
every receiver is different and may react differently to an identical receiver and bin..
Username: Runnerguy
Pluto
Post Number: 185
You sure your autoroll is off?
