Gold Member Username: CavsmaximaNew York United States Post Number: 1068 Registered: Aug-06 | what can 3 4 ohm subs be wired down to? |
Silver Member Username: OlegSanta Monica, CA USA Post Number: 880 Registered: Nov-04 | 3 SVC 4ohm subs can be wired to 1.333ohms 3 DVC 4ohm subs can be wired to 0.667ohms or 2.667ohms and of course you can achieve higher loads by wiring everything in series |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1476 Registered: Jul-06 | http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=3&woofer_imp=1 |
Silver Member Username: J_c_wheeler8Columbus, IN United States Post Number: 215 Registered: May-06 | how would u find an amp with an output of 1.34 ohms? Since there are no other wiring options for those specific requirments |
Gold Member Username: Nd4spd18Southeast PA Post Number: 1646 Registered: Jul-06 | ^^^^^^ You would use a 1 ohm stable amp. You would get more power than it's rated for a 2 ohms, but less than what it's rated for at 1 ohm. |
